주요 콘텐츠로 건너뛰기
Aluratek ADMPF310F Replacing USB Port Replacement
필요한 것
  1. Aluratek ADMPF310F Replacing USB Port Replacement, Motherboard: 1 단계, 이미지 3개 중 1개 Aluratek ADMPF310F Replacing USB Port Replacement, Motherboard: 1 단계, 이미지 3개 중 2개 Aluratek ADMPF310F Replacing USB Port Replacement, Motherboard: 1 단계, 이미지 3개 중 3개
    • Using the black nylon spudger, pry off the clips all around the frame. You will hear a popping sound for every clip
    • Be sure not to pry to hard because you could crack or break the plastic facing of the device.
  2. Aluratek ADMPF310F Replacing USB Port Replacement: 2 단계, 이미지 1개 중 1개
    • Lift screen out of place so you can access the plugs that connect it.
  3. Aluratek ADMPF310F Replacing USB Port Replacement: 3 단계, 이미지 2개 중 1개 Aluratek ADMPF310F Replacing USB Port Replacement: 3 단계, 이미지 2개 중 2개
    • Using the plastic spudger tool lift the plastic zif(zero instertion force) connector clip up.
    • Pull the ribbon cable away from the mother board.
    • Be careful as this zif connector is very frail plastic.
  4. Aluratek ADMPF310F Replacing USB Port Replacement: 4 단계, 이미지 1개 중 1개
    • Disconnect the red and black cable connecting the screen to the motherboard by just pulling it out.
  5. Aluratek ADMPF310F Replacing USB Port Replacement: 5 단계, 이미지 1개 중 1개
    • Pull out remote receiver out of its clip.
    • Be careful to not move the wires around for the remote receiver too much, as they are soldered to the motherboard.
  6. Aluratek ADMPF310F Replacing USB Port Replacement: 6 단계, 이미지 2개 중 1개 Aluratek ADMPF310F Replacing USB Port Replacement: 6 단계, 이미지 2개 중 2개
    • Using fingers pull the first speaker wire that is located closest to the speakers
    • Again using your fingers, pull out the second speaker wire near the far side of the motherboard.
  7. Aluratek ADMPF310F Replacing USB Port Replacement: 7 단계, 이미지 3개 중 1개 Aluratek ADMPF310F Replacing USB Port Replacement: 7 단계, 이미지 3개 중 2개 Aluratek ADMPF310F Replacing USB Port Replacement: 7 단계, 이미지 3개 중 3개
    • Using the ph0 phillips head screwdriver unscrew the four 4mm screws circled in the picture.
  8. Aluratek ADMPF310F Replacing USB Port Replacement: 8 단계, 이미지 1개 중 1개
    • Pull up the smaller end of the motherboard.
    • Apply force pulling away from the USB ports to get the mother board out of place.
  9. Aluratek ADMPF310F Replacing USB Port Replacement, USB Port: 9 단계, 이미지 1개 중 1개
    • On the back end of the mother board unsolder the USB port at the two points shown.
결론
작성자
2다른 기여자 명과 함께
Pascal Alexis
회원 가입일: 11/05/15
427 평판
안내서 3개를 작성함
UMass Dartmouth, Team 5-1, Martin Fall 2016 UMass Dartmouth, Team 5-1, Martin Fall 2016 회원
UMASSD-MARTIN-F16S5G1
3 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 15
전체 시간: 295
