주요 콘텐츠로 건너뛰기
Aluratek ADMPF310F Speakers Replacement
필요한 것
  1. Aluratek ADMPF310F Speakers Replacement, Speakers: 1 단계, 이미지 1/3 Aluratek ADMPF310F Speakers Replacement, Speakers: 1 단계, 이미지 2/3 Aluratek ADMPF310F Speakers Replacement, Speakers: 1 단계, 이미지 3/3
    • Using the plastic opening tool pry off the clips all around the frame. You will hear a popping sound for every clip
    • Be sure not to pry to hard because you could crack or break the plastic facing of the device.
  2. Aluratek ADMPF310F Speakers Replacement: 2 단계, 이미지 1/1
    • Lift screen out of place so you can access the plugs that connect it.
    • Be careful not to pull the screen to far away when placing to the side, many fragile wires are connected.
  3. Aluratek ADMPF310F Speakers Replacement: 3 단계, 이미지 1/2 Aluratek ADMPF310F Speakers Replacement: 3 단계, 이미지 2/2
    • Unplug both plugs for the speakers to the motherboard
  4. Aluratek ADMPF310F Speakers Replacement: 4 단계, 이미지 1/2 Aluratek ADMPF310F Speakers Replacement: 4 단계, 이미지 2/2
    • Use plastic opening tool to pull out one of the speakers.
    • Then use your hand to take out the other speaker
  5. Aluratek ADMPF310F Speakers Replacement: 5 단계, 이미지 1/1
    • Disconnect the wires off of the old speakers and solder the old wires onto the new speakers.
결론
Chris Belair
회원 가입일: 10/20/16
333 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 5-1, Martin Fall 2016 UMass Dartmouth, Team 5-1, Martin Fall 2016 회원
UMASSD-MARTIN-F16S5G1
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 14
전체 시간: 117
