주요 콘텐츠로 건너뛰기
Amana Washing Machine NTW4516FW Shift Actuator Replacement
필요한 것
  1. Amana Washing Machine NTW4516FW Shift Actuator Replacement, Shift Actuator: 1 단계, 이미지 3개 중 1개 Amana Washing Machine NTW4516FW Shift Actuator Replacement, Shift Actuator: 1 단계, 이미지 3개 중 2개 Amana Washing Machine NTW4516FW Shift Actuator Replacement, Shift Actuator: 1 단계, 이미지 3개 중 3개
    • To work on this replacement, you will need to gain access to the bottom. It is best to place the washer on its front. Place a few old blankets etc. so as not to scratch the front to much. Since I did a total rebuild on this washer, I had also removed the control panel. It was easier for me to place the washer upside down :-)
    • Not shown here is that you need to unplug the washer as well as disconnect the water supply hoses prior to working on it!
    • First the pulley cover has to be removed. It is attached via two 5/16 bolts
    • Use an electric screwdriver with a short extension and a 5/16 socket to remove the right screw,
  2. Amana Washing Machine NTW4516FW Shift Actuator Replacement: 2 단계, 이미지 3개 중 1개 Amana Washing Machine NTW4516FW Shift Actuator Replacement: 2 단계, 이미지 3개 중 2개 Amana Washing Machine NTW4516FW Shift Actuator Replacement: 2 단계, 이미지 3개 중 3개
    • followed by the left screw, is easiest. A hand ratchet or a nut driver will of course work as well.
    • Remove the pulley cover
    • Now clearly visible are
    • The motor
    • The pulley for the drive (clutch/splutch is underneath)
    • The shift actuator
    • The start capacitor for the motor
  3. Amana Washing Machine NTW4516FW Shift Actuator Replacement: 3 단계, 이미지 3개 중 1개 Amana Washing Machine NTW4516FW Shift Actuator Replacement: 3 단계, 이미지 3개 중 2개 Amana Washing Machine NTW4516FW Shift Actuator Replacement: 3 단계, 이미지 3개 중 3개
    • Here is a close up of the shift actuator
    • Remove the electrical connector by squeezing the locking tab down and pulling the connector off.
    • The actuator is held in place by two Philips head screws. Here they are actually using two green colored screws
  4. Amana Washing Machine NTW4516FW Shift Actuator Replacement: 4 단계, 이미지 3개 중 1개 Amana Washing Machine NTW4516FW Shift Actuator Replacement: 4 단계, 이미지 3개 중 2개 Amana Washing Machine NTW4516FW Shift Actuator Replacement: 4 단계, 이미지 3개 중 3개
    • Use a #2 Philips screwdriver to remove the left
    • and right screw.
    • Remove the actuator by pulling it up so that the pin clears the shifter assembly
  5. Amana Washing Machine NTW4516FW Shift Actuator Replacement: 5 단계, 이미지 2개 중 1개 Amana Washing Machine NTW4516FW Shift Actuator Replacement: 5 단계, 이미지 2개 중 2개
    • Shift actuator removed and the shifter is now fully visible
    • Calibration Cycle must be run whenever a main component i.e. main control, motor, pump etc. has been replaced. To run the cycle, use the instructions received from the seller of the actuator. Or you can use the Tech Sheet for this washer and follow the instructions on page 4
결론
다른 2명이 해당 안내서를 완성하였습니다.
첨부 문서
작성자
1다른 기여자 명과 함께
oldturkey03
회원 가입일: 09/29/10
836,854 평판
안내서 123개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 16
지난 30일: 55
전체 시간: 506
