주요 콘텐츠로 건너뛰기
Amazon Echo Show 10 3rd Gen Power Jack Replacement
필요한 것
  1. Amazon Echo Show 10 3rd Gen Power Jack Replacement, Power Jack: 1 단계, 이미지 2개 중 1개 Amazon Echo Show 10 3rd Gen Power Jack Replacement, Power Jack: 1 단계, 이미지 2개 중 2개
    • With the echo device standing upright, firmly grip the base and use the blue opening tool to gently pry the lid from the mesh speaker base.
    • Remove the lid and set it aside.
  2. Amazon Echo Show 10 3rd Gen Power Jack Replacement: 2 단계, 이미지 1개 중 1개
    • Use a TR8 Torx Security to remove the six 9 mm screws from the perimeter of the plastic bezel on the top edge of the device.
  3. Amazon Echo Show 10 3rd Gen Power Jack Replacement: 3 단계, 이미지 2개 중 1개 Amazon Echo Show 10 3rd Gen Power Jack Replacement: 3 단계, 이미지 2개 중 2개
    • Release the adhesive seal connecting the bezel to the main base by inserting a Jimmy underneath the edge, and gently sliding from one side to another.
    • Lift up the outermost edge of the plastic bezel (furthest from the display) to remove it and set it aside.
    • After removing the screws in the previous step, the only thing holding this component in place is glue. You may need to apply a little force to break the seal created by any remaining glue to remove the bezel component. You could also apply a little heat with the iOpener to loosen the adhesive.
  4. Amazon Echo Show 10 3rd Gen Power Jack Replacement: 4 단계, 이미지 1개 중 1개
    • Use a Torx T6 screwdriver to remove the five 10 mm screws from the perimeter of the top surface of the base.
  5. Amazon Echo Show 10 3rd Gen Power Jack Replacement: 5 단계, 이미지 2개 중 1개 Amazon Echo Show 10 3rd Gen Power Jack Replacement: 5 단계, 이미지 2개 중 2개
    • With one hand securely holding the neck of the display and the other holding the device base, gently lift the device out of the mesh shell.
    • Place the shell aside.
  6. Amazon Echo Show 10 3rd Gen Power Jack Replacement: 6 단계, 이미지 2개 중 1개 Amazon Echo Show 10 3rd Gen Power Jack Replacement: 6 단계, 이미지 2개 중 2개
    • Turn the device on its side with the bottom facing upwards and out.
    • Use a blue opening tool along the edge of the base to pry off the adhesive strip.
    • Gently pull off the strip and place it aside.
    • A little force is necessary to separate the rubber strip from the feet of the device.
  7. Amazon Echo Show 10 3rd Gen Power Jack Replacement: 7 단계, 이미지 2개 중 1개 Amazon Echo Show 10 3rd Gen Power Jack Replacement: 7 단계, 이미지 2개 중 2개
    • Use a Torx T10 screwdriver to remove the four 9 mm screws from the perimeter of the bottom surface of the device.
    • Remove the plastic base cover and set it aside.
  8. Amazon Echo Show 10 3rd Gen Power Jack Replacement: 8 단계, 이미지 2개 중 1개 Amazon Echo Show 10 3rd Gen Power Jack Replacement: 8 단계, 이미지 2개 중 2개
    • Use a nylon spudger to flip up the small locking flap on the ribbon cable connector and gently pull the cable out.
  9. Amazon Echo Show 10 3rd Gen Power Jack Replacement: 9 단계, 이미지 1개 중 1개
    • Use a Torx T6 screwdriver to remove the three 9 mm screws from the power board.
  10. Amazon Echo Show 10 3rd Gen Power Jack Replacement: 10 단계, 이미지 1개 중 1개
    • Lift the power board from the base.
결론
작성자
1다른 기여자 명과 함께
Macy Ormand
회원 가입일: 09/13/23
1,094 평판
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 23
전체 시간: 360
