주요 콘텐츠로 건너뛰기
Amazon Echo Show 10 3rd Gen Speaker PCB Replacement
필요한 것
  1. Amazon Echo Show 10 3rd Gen Speaker PCB Replacement, Tweeter: 1 단계, 이미지 2개 중 1개 Amazon Echo Show 10 3rd Gen Speaker PCB Replacement, Tweeter: 1 단계, 이미지 2개 중 2개
    • With the echo device standing upright, firmly grip the base and use the blue opening tool to gently pry the lid from the mesh speaker base.
    • Remove the lid and set it aside.
  2. Amazon Echo Show 10 3rd Gen Speaker PCB Replacement: 2 단계, 이미지 1개 중 1개
    • Use a TR8 Torx Security screwdriver to remove the six 9 mm screws from the perimeter of the plastic bezel on the top edge of the device.
  3. Amazon Echo Show 10 3rd Gen Speaker PCB Replacement: 3 단계, 이미지 2개 중 1개 Amazon Echo Show 10 3rd Gen Speaker PCB Replacement: 3 단계, 이미지 2개 중 2개
    • Release the adhesive seal connecting the bezel to the main base by inserting a Jimmy underneath the edge, and gently sliding from one side to another.
    • Lift up the outermost edge of the plastic bezel (furthest from the display) to remove it and set it aside.
    • After removing the screws in the previous step, the only thing holding this component in place is glue. You may need to apply a little force to break the seal created by any remaining glue to remove the bezel component. You could also apply a little heat with the iOpener to loosen the adhesive.
  4. Amazon Echo Show 10 3rd Gen Speaker PCB Replacement: 4 단계, 이미지 1개 중 1개
    • Use a Torx T6 screwdriver to remove the five 10 mm screws from the perimeter of the top surface of the base.
  5. Amazon Echo Show 10 3rd Gen Speaker PCB Replacement: 5 단계, 이미지 2개 중 1개 Amazon Echo Show 10 3rd Gen Speaker PCB Replacement: 5 단계, 이미지 2개 중 2개
    • With one hand securely holding the neck of the display and the other holding the device base, gently lift the device out of the mesh shell.
    • Place the shell aside.
  6. Amazon Echo Show 10 3rd Gen Speaker PCB Replacement: 6 단계, 이미지 2개 중 1개 Amazon Echo Show 10 3rd Gen Speaker PCB Replacement: 6 단계, 이미지 2개 중 2개
    • Rotate the device to lay on its side with the tweeter's exterior facing you.
    • Unhook the 3-pin connector attaching the tweeter to the base with your fingers. Hold it as close to the base of the cord as possible, and lift it directly up from the socket.
  7. Amazon Echo Show 10 3rd Gen Speaker PCB Replacement: 7 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the four 10 mm screws attaching the tweeter to the main speaker base.
  8. Amazon Echo Show 10 3rd Gen Speaker PCB Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the tweeter.
    • Repeat the previous steps if you are removing the other tweeter.
  9. Amazon Echo Show 10 3rd Gen Speaker PCB Replacement, Speaker PCB: 9 단계, 이미지 1개 중 1개
    • Remove the six 6.8 mm T6 Torx screws.
  10. Amazon Echo Show 10 3rd Gen Speaker PCB Replacement: 10 단계, 이미지 2개 중 1개 Amazon Echo Show 10 3rd Gen Speaker PCB Replacement: 10 단계, 이미지 2개 중 2개
    • Gently lift up the press connector to disconnect it.
    • Remove the PCB.
  11. Amazon Echo Show 10 3rd Gen Speaker PCB Replacement: 11 단계, 이미지 2개 중 1개 Amazon Echo Show 10 3rd Gen Speaker PCB Replacement: 11 단계, 이미지 2개 중 2개
    • Remove the four 10.7 mm T8 Torx screws.
  12. Amazon Echo Show 10 3rd Gen Speaker PCB Replacement: 12 단계, 이미지 1개 중 1개
    • Remove the two 6.8 mm T6 Torx screws that secure the bracket.
  13. Amazon Echo Show 10 3rd Gen Speaker PCB Replacement: 13 단계, 이미지 2개 중 1개 Amazon Echo Show 10 3rd Gen Speaker PCB Replacement: 13 단계, 이미지 2개 중 2개
    • Remove the two 9.3 mm T6 Torx screws that secure the speaker PCB.
    • Remove the speaker PCB.
결론
작성자
2다른 기여자 명과 함께
jasmanathwal
회원 가입일: 04/01/24
121 평판
안내서 1개를 작성함
IUPUI, Team 1-3, Harley Spring 2024 IUPUI, Team 1-3, Harley Spring 2024 회원
IUPUI-HARLEY-S24S1G3
4 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 27
전체 시간: 204
