주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Amazon Echo Show 8 2nd Generation Camera Replacement
필요한 것
    1. Amazon Echo Show 8 2nd Generation Camera Replacement, Rear Case: 1 단계, 이미지 3개 중 1개 Amazon Echo Show 8 2nd Generation Camera Replacement, Rear Case: 1 단계, 이미지 3개 중 2개 Amazon Echo Show 8 2nd Generation Camera Replacement, Rear Case: 1 단계, 이미지 3개 중 3개
      • Flip the device so that the rubber foot is facing up.
      • Insert a Jimmy between the rubber foot and chassis, then slide it around the perimeter until the rubber foot releases.
      • The adhesive that holds the rubber mat on may require some force to sever.
      • Remove the rubber foot.
      댓글 쓰기
    2. Amazon Echo Show 8 2nd Generation Camera Replacement: 2 단계, 이미지 3개 중 1개 Amazon Echo Show 8 2nd Generation Camera Replacement: 2 단계, 이미지 3개 중 2개 Amazon Echo Show 8 2nd Generation Camera Replacement: 2 단계, 이미지 3개 중 3개
      • Use a T6 Torx screwdriver to remove the five 4.5 mm screws from the base of the device.
      댓글 쓰기
    3. Amazon Echo Show 8 2nd Generation Camera Replacement: 3 단계, 이미지 3개 중 1개 Amazon Echo Show 8 2nd Generation Camera Replacement: 3 단계, 이미지 3개 중 2개 Amazon Echo Show 8 2nd Generation Camera Replacement: 3 단계, 이미지 3개 중 3개
      • Insert a Jimmy in the gap between the front and rear case.
      • Work the Jimmy around the perimeter to gently detach the rear case from the front case.
      • Separate the rear case from the front case.
      • There are 2 thin ribbon cables connecting the microphone board to the back cover. Take care not to tear or strain them as you separate the cases.
      댓글 쓰기
    4. Amazon Echo Show 8 2nd Generation Camera Replacement: 4 단계, 이미지 3개 중 1개 Amazon Echo Show 8 2nd Generation Camera Replacement: 4 단계, 이미지 3개 중 2개 Amazon Echo Show 8 2nd Generation Camera Replacement: 4 단계, 이미지 3개 중 3개
      • Use a T6 Torx screwdriver to remove the four 5.2 mm screws that secure the microphone board to the rear case.
      댓글 쓰기
    1. Amazon Echo Show 8 2nd Generation Camera Replacement, Camera: 5 단계, 이미지 3개 중 1개 Amazon Echo Show 8 2nd Generation Camera Replacement, Camera: 5 단계, 이미지 3개 중 2개 Amazon Echo Show 8 2nd Generation Camera Replacement, Camera: 5 단계, 이미지 3개 중 3개
      • Use a T6 Torx screwdriver to remove the six 7.6 mm screws that secure the speaker housing to the screen assembly.
      • There is a screw that is not pictured in the center of the bottom two screws.
      댓글 쓰기
    2. Amazon Echo Show 8 2nd Generation Camera Replacement: 6 단계, 이미지 3개 중 1개 Amazon Echo Show 8 2nd Generation Camera Replacement: 6 단계, 이미지 3개 중 2개 Amazon Echo Show 8 2nd Generation Camera Replacement: 6 단계, 이미지 3개 중 3개
      • Gently separate the speaker housing from the display assembly and set the device on a flat surface.
      • There is a cable connecting the speaker housing to the display assembly. Take care not to pull on it while separating the two parts.
      • Use a plastic spudger to pry up and remove the foam mat at the center of the silver bracket.
      댓글 쓰기
    3. Amazon Echo Show 8 2nd Generation Camera Replacement: 7 단계, 이미지 2개 중 1개 Amazon Echo Show 8 2nd Generation Camera Replacement: 7 단계, 이미지 2개 중 2개
      • Use a T6 Torx screwdriver to remove the eleven 6 mm screws that secure the silver bracket.
      댓글 쓰기
    4. Amazon Echo Show 8 2nd Generation Camera Replacement: 8 단계, 이미지 3개 중 1개 Amazon Echo Show 8 2nd Generation Camera Replacement: 8 단계, 이미지 3개 중 2개 Amazon Echo Show 8 2nd Generation Camera Replacement: 8 단계, 이미지 3개 중 3개
      • Use a plastic spudger to lift up the remove the silver bracket.
      • The camera is located to the left of the mother board.
      댓글 쓰기
    5. Amazon Echo Show 8 2nd Generation Camera Replacement: 9 단계, 이미지 3개 중 1개 Amazon Echo Show 8 2nd Generation Camera Replacement: 9 단계, 이미지 3개 중 2개 Amazon Echo Show 8 2nd Generation Camera Replacement: 9 단계, 이미지 3개 중 3개
      • Use a T6 Torx screwdriver to remove the two 6 mm screws that secure the camera retention plate.
      댓글 쓰기
    6. Amazon Echo Show 8 2nd Generation Camera Replacement: 10 단계, 이미지 3개 중 1개 Amazon Echo Show 8 2nd Generation Camera Replacement: 10 단계, 이미지 3개 중 2개 Amazon Echo Show 8 2nd Generation Camera Replacement: 10 단계, 이미지 3개 중 3개
      • Use a spudger to slightly lift the camera retention plate.
      • Lift the camera retention plate up and out of the chassis.
      댓글 쓰기
    7. Amazon Echo Show 8 2nd Generation Camera Replacement: 11 단계, 이미지 2개 중 1개 Amazon Echo Show 8 2nd Generation Camera Replacement: 11 단계, 이미지 2개 중 2개
      • Use the pointed end of a spudger to flip up the camera ribbon cable ZIF locking flap.
      • Pull the ribbon cable directly out of its socket.
      댓글 쓰기
    8. Amazon Echo Show 8 2nd Generation Camera Replacement: 12 단계, 이미지 2개 중 1개 Amazon Echo Show 8 2nd Generation Camera Replacement: 12 단계, 이미지 2개 중 2개
      • Lift up the camera gently, and use the pointed end of the spudger to gently remove the thin black ribbon cable.
      • The thin tab holding is held down with adhesive. Be gentle when removing it to prevent tearing it.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Brian Le
회원 가입일: 02/14/24
690 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 37
전체 시간: 620
