소개
Use this replacement guide if the camera of the Amazon Echo Show 8 is not functioning. The camera is important when it comes to unlocking the device using facial recognition and video calling. Before continuing with this replacement guides, go to the troubleshooting guide and ensure you have completed the trouble shooting steps. This guide will walk you through replacing the camera. Make sure the device is disconnected from the power before proceeding with the guide.
필요한 것
Flip the device so that the rubber foot is facing up.
Insert a Jimmy between the rubber foot and chassis, then slide it around the perimeter until the rubber foot releases.
Remove the rubber foot.
Use a T6 Torx screwdriver to remove the six 7.6 mm screws that secure the speaker housing to the screen assembly.
