주요 콘텐츠로 건너뛰기
Amazon Echo Show 8 2nd Generation Microphone Board Replacement
필요한 것
  1. Amazon Echo Show 8 2nd Generation Microphone Board Replacement, Rear Case: 1 단계, 이미지 1/3 Amazon Echo Show 8 2nd Generation Microphone Board Replacement, Rear Case: 1 단계, 이미지 2/3 Amazon Echo Show 8 2nd Generation Microphone Board Replacement, Rear Case: 1 단계, 이미지 3/3
    • Flip the device so that the rubber foot is facing up.
    • Insert a Jimmy between the rubber foot and chassis, then slide it around the perimeter until the rubber foot releases.
    • The adhesive that holds the rubber mat on may require some force to sever.
    • Remove the rubber foot.
  2. Amazon Echo Show 8 2nd Generation Microphone Board Replacement: 2 단계, 이미지 1/3 Amazon Echo Show 8 2nd Generation Microphone Board Replacement: 2 단계, 이미지 2/3 Amazon Echo Show 8 2nd Generation Microphone Board Replacement: 2 단계, 이미지 3/3
    • Use a T6 Torx screwdriver to remove the five 4.5 mm screws from the base of the device.
  3. Amazon Echo Show 8 2nd Generation Microphone Board Replacement: 3 단계, 이미지 1/3 Amazon Echo Show 8 2nd Generation Microphone Board Replacement: 3 단계, 이미지 2/3 Amazon Echo Show 8 2nd Generation Microphone Board Replacement: 3 단계, 이미지 3/3
    • Insert a Jimmy in the gap between the front and rear case.
    • Work the Jimmy around the perimeter to gently detach the rear case from the front case.
    • Separate the rear case from the front case.
    • There are 2 thin ribbon cables connecting the microphone board to the back cover. Take care not to tear or strain them as you separate the cases.
  4. Amazon Echo Show 8 2nd Generation Microphone Board Replacement: 4 단계, 이미지 1/3 Amazon Echo Show 8 2nd Generation Microphone Board Replacement: 4 단계, 이미지 2/3 Amazon Echo Show 8 2nd Generation Microphone Board Replacement: 4 단계, 이미지 3/3
    • Use a T6 Torx screwdriver to remove the four 5.25 mm screws that secure the microphone board to the rear case.
  5. Amazon Echo Show 8 2nd Generation Microphone Board Replacement, Microphone: 5 단계, 이미지 1/3 Amazon Echo Show 8 2nd Generation Microphone Board Replacement, Microphone: 5 단계, 이미지 2/3 Amazon Echo Show 8 2nd Generation Microphone Board Replacement, Microphone: 5 단계, 이미지 3/3
    • Orient the Echo with the microphone board facing upwards.
    • Use a spudger to gently remove the 2 pieces of foam covering the ribbon cables.
  6. Amazon Echo Show 8 2nd Generation Microphone Board Replacement: 6 단계, 이미지 1/3 Amazon Echo Show 8 2nd Generation Microphone Board Replacement: 6 단계, 이미지 2/3 Amazon Echo Show 8 2nd Generation Microphone Board Replacement: 6 단계, 이미지 3/3
    • Use the pointed end of a spudger to flip up both of the ZIF locking flaps.
    • Gently remove both of the ribbon cables from their respective sockets.
    • Lift the micro
결론
Micayla Muturi
회원 가입일: 02/14/24
169 평판
안내서 2개 작성하였습니다
University of Memphis, Team 1-3, Sneed Spring 2024 University of Memphis, Team 1-3, Sneed Spring 2024 회원
UM-SNEED-S24S1G3
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 23
전체 시간: 61
