주요 콘텐츠로 건너뛰기
Amazon Fire HD 8 12th Gen Speakers Replacement
필요한 것
  1. 주의: 1-2 단계들은 진행 중으로 표시된 안내서에서 제공되었습니다.
    Amazon Fire HD 8 12th Gen Speakers Replacement, Buttons: 1 단계, 이미지 1/3 Amazon Fire HD 8 12th Gen Speakers Replacement, Buttons: 1 단계, 이미지 2/3 Amazon Fire HD 8 12th Gen Speakers Replacement, Buttons: 1 단계, 이미지 3/3
    • Remove the device from any electrical source and make sure it is powered off.
    • Put picks around the corner and move them along the edge to pry the case off.
    • Once there is separation between the case and the screen, place a pick in between the screen and on the corner of the back case.
  2. Amazon Fire HD 8 12th Gen Speakers Replacement: 2 단계, 이미지 1/2 Amazon Fire HD 8 12th Gen Speakers Replacement: 2 단계, 이미지 2/2
    • With the corners lifted, take the opening tool and pry each corner off.
    • Repeat this for the corner diagonal from the initial corner.
    • Once both corners are pried off, gently take the back case off the device.
  3. Amazon Fire HD 8 12th Gen Speakers Replacement, Speakers: 3 단계, 이미지 1/1
    • Disconnect the red and black wires connected to the motherboard.
  4. Amazon Fire HD 8 12th Gen Speakers Replacement: 4 단계, 이미지 1/3 Amazon Fire HD 8 12th Gen Speakers Replacement: 4 단계, 이미지 2/3 Amazon Fire HD 8 12th Gen Speakers Replacement: 4 단계, 이미지 3/3
    • Heat glue up to loosen the black and red wires, then lift and remove black and red wires.
    • Be careful of hot metals/parts and hot tools.
  5. Amazon Fire HD 8 12th Gen Speakers Replacement: 5 단계, 이미지 1/3 Amazon Fire HD 8 12th Gen Speakers Replacement: 5 단계, 이미지 2/3 Amazon Fire HD 8 12th Gen Speakers Replacement: 5 단계, 이미지 3/3
    • Get metal speaker parts hot as well and lift the metal speaker up.
    • Do this for the other set of speakers and repeat the steps again.
    • Be careful of hot tools and hot parts.
결론
Jaden Palmer
회원 가입일: 09/06/23
485 평판
안내서 4개 작성하였습니다
University of Memphis, Team 1-1, Sneed Fall 2023 University of Memphis, Team 1-1, Sneed Fall 2023 회원
UM-SNEED-F23S1G1
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 11
전체 시간: 75
