주요 콘텐츠로 건너뛰기
Amazon Fire TV Power Cord Port Replacement
필요한 것
  1. Amazon Fire TV Power Cord Port Replacement, Motherboard: 1 단계, 이미지 1/3 Amazon Fire TV Power Cord Port Replacement, Motherboard: 1 단계, 이미지 2/3 Amazon Fire TV Power Cord Port Replacement, Motherboard: 1 단계, 이미지 3/3
    • Place the plastic opening tool in the space between the rubber and the plastic case of the device.
    • Apply pressure by pushing upward on the case.
    • Separate the bottom square rubber piece from the case using the plastic opening tool until all clips are detached.
  2. Amazon Fire TV Power Cord Port Replacement: 2 단계, 이미지 1/2 Amazon Fire TV Power Cord Port Replacement: 2 단계, 이미지 2/2
    • Locate the ten J#00 Phillips screws and remove them.
  3. Amazon Fire TV Power Cord Port Replacement: 3 단계, 이미지 1/3 Amazon Fire TV Power Cord Port Replacement: 3 단계, 이미지 2/3 Amazon Fire TV Power Cord Port Replacement: 3 단계, 이미지 3/3
    • Place your finger on the short edge of the motherboard and lift it to separate it from the plastic case.
  4. Amazon Fire TV Power Cord Port Replacement, Power Cord Port: 4 단계, 이미지 1/3 Amazon Fire TV Power Cord Port Replacement, Power Cord Port: 4 단계, 이미지 2/3 Amazon Fire TV Power Cord Port Replacement, Power Cord Port: 4 단계, 이미지 3/3
    • With the mother board back facing you locate the power cord port found on the far left end.
  5. Amazon Fire TV Power Cord Port Replacement: 5 단계, 이미지 1/3 Amazon Fire TV Power Cord Port Replacement: 5 단계, 이미지 2/3 Amazon Fire TV Power Cord Port Replacement: 5 단계, 이미지 3/3
    • Locate the four soldering joints for the power cord port found on the top side of the mother board.
    • Desolder the joints of the power cord port to release it from the motherboard.
    • Place the new power cord port into its original location and solder its joints.
    • Use the iFixit soldering and desoldering guide.
결론
다른 5명이 해당 안내서를 완성하였습니다.
jeffrey555
회원 가입일: 09/01/15
424 평판
안내서 2개 작성하였습니다
USF Tampa, Team 16-3, Wollert Fall 2015 USF Tampa, Team 16-3, Wollert Fall 2015 회원
USFT-WOLLERT-F15S16G3
4 회원들
안내서 16개 작성하였습니다
댓글 2개
Aonde compro essa fonte ? wagnerj957@gmail.com
wagnerjr1977 - 답글
Ola moro no Brasil minha fonte queimou aonde compro outra?
wagnerjr1977 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 27
전체 시간: 2,781
