주요 콘텐츠로 건너뛰기
Anker 2.4G Wireless Mouse Battery Replacement
필요한 것
  1. Anker 2.4G Wireless Mouse Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Remove the battery cover with a plastic opening tool, nylon spudger, or a fingernail.
  2. Anker 2.4G Wireless Mouse Battery Replacement: 2 단계, 이미지 1/1
    • Remove the battery with a finger nail or a nonmetal tool.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Vincent Lee
회원 가입일: 01/23/14
361 평판
안내서 3개 작성하였습니다
Cal Poly, Team 1-39, Maness Winter 2014 Cal Poly, Team 1-39, Maness Winter 2014 회원
CPSU-MANESS-W14S1G39
4 회원들
안내서 16개 작성하였습니다
댓글 2개
My Anker vertical wireless mouse uses 2 "AAA" batteries. It is Model TMI56G. Batteries are fresh. Dongle is new. The mouse worked fine with the dongle that was broken prior to the company sending me a replacement. The highest bar on the thumb side on the mouse comes on and glows red briefly when I turn the mouse on. There is no clear button on top of the mouse. I have Windows 10 and when I check my settings I keep getting an "ERROR CODE 10" FOR MY ANKER Mouse. My LOGITECH mouse works just fine when I plug into the same USB port. Could I have been sent the wrong dongle for my ANKER Mouse? Please advise.
Thank You,
Richard Johnson
mutantear@comcast.net
Rick Johnson - 답글
Any help would be appreciated. I need to return the LOGTECH mouse I'm now using to it's owner.
Thanks,
Rick
Rick Johnson - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 26
전체 시간: 5,603
