주요 콘텐츠로 건너뛰기
Anker 2.4G Wireless Mouse Sensor Replacement
필요한 것
  1. Anker 2.4G Wireless Mouse Sensor Replacement, Sensor: 1 단계, 이미지 1개 중 1개
    • Using a spudger, carefully pry off the stickers to reveal the location of four screws.
  2. Anker 2.4G Wireless Mouse Sensor Replacement: 2 단계, 이미지 1개 중 1개
    • Using your Phillips screwdriver, remove the four screws.
  3. Anker 2.4G Wireless Mouse Sensor Replacement: 3 단계, 이미지 2개 중 1개 Anker 2.4G Wireless Mouse Sensor Replacement: 3 단계, 이미지 2개 중 2개
    • Using a spudger, carefully pry apart the upper and lower housing of the mouse.
    • Make sure you are not using too much pressure, as you could warp the plastic.
  4. Anker 2.4G Wireless Mouse Sensor Replacement: 4 단계, 이미지 1개 중 1개
    • Disconnect the wires from the white crimping headers.
    • Pull as far up on the wire as possible, but be careful to avoid ripping the wires.
  5. Anker 2.4G Wireless Mouse Sensor Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the scroll wheel from the motherboard by pulling it to the left.
    • This may take some force to remove. Make sure to pull it parallel to the board, instead of perpendicularly.
  6. Anker 2.4G Wireless Mouse Sensor Replacement: 6 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Anti-Static Wrist Strap
    $7.95
    • Gently lift the motherboard away from the plastic housing.
    • Use an iFixit grounding strap or another antistatic measure to prevent sensitive components from electrostatic discharge during this step.
  7. Anker 2.4G Wireless Mouse Sensor Replacement: 7 단계, 이미지 1개 중 1개
    • Desolder the six wires holding the I.C. in place to complete the sensor change.
    • Replace the broken sensor with the new sensor and solder back in place.
    • Make sure none of your solder connections are bridged as this can cause serious damage to your mouse.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
12다른 기여자 명과 함께
Ryan
회원 가입일: 01/23/14
140 평판
안내서 1개를 작성함
Cal Poly, Team 1-39, Maness Winter 2014 Cal Poly, Team 1-39, Maness Winter 2014 회원
CPSU-MANESS-W14S1G39
4 회원들
안내서 16개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 41
전체 시간: 8,044
