주요 콘텐츠로 건너뛰기
Anker SoundCore 2 Speaker Replacement
필요한 것
  1. Anker SoundCore 2 Speaker Replacement, Front Panel: 1 단계, 이미지 2개 중 1개 Anker SoundCore 2 Speaker Replacement, Front Panel: 1 단계, 이미지 2개 중 2개
    • Insert a spudger between the front panel and the body of the speaker.
    • Pry around the edges of the front panel with the spudger to pry it away from the speaker body.
  2. Anker SoundCore 2 Speaker Replacement, Speaker: 2 단계, 이미지 3개 중 1개 Anker SoundCore 2 Speaker Replacement, Speaker: 2 단계, 이미지 3개 중 2개 Anker SoundCore 2 Speaker Replacement, Speaker: 2 단계, 이미지 3개 중 3개
    • Remove eight 10 mm screws from the speaker mount using a Phillips #0 screwdriver.
    • Insert a spudger in the gap between the speaker mount and speaker body to remove the speaker mount.
    • Use your hand to remove the speakers.
  3. Anker SoundCore 2 Speaker Replacement: 3 단계, 이미지 3개 중 1개 Anker SoundCore 2 Speaker Replacement: 3 단계, 이미지 3개 중 2개 Anker SoundCore 2 Speaker Replacement: 3 단계, 이미지 3개 중 3개
    • The speakers do not use wires so when replacing the speaker, make sure you align the metal prongs with the metal clips on the motherboard.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Tripp Lersch
회원 가입일: 01/14/21
408 평판
안내서 4개를 작성함
12가이드 댓글
Excellent guide, my speaker falls to the ground, and one of two speaker stops working, disassemble and verifying, was the speaker clip was loose
Renato Galindo - 답글
Where can I buy a speaker for the repair ? Or will any sized speaker work ?
philcuchetti - 답글
hi, did you manage to buy a replacement speaker? If yes from where pls?
jafarez -
Do someone get a new speaker? I need to buy one!
everton.euclides - 답글
jafarez -
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 25
지난 30일: 92
전체 시간: 6,323
