주요 콘텐츠로 건너뛰기
Anki Vector LCD Facial Display Replacement
필요한 것
  1. Anki Vector LCD Facial Display Replacement, LCD Facial Display: 1 단계, 이미지 3개 중 1개 Anki Vector LCD Facial Display Replacement, LCD Facial Display: 1 단계, 이미지 3개 중 2개 Anki Vector LCD Facial Display Replacement, LCD Facial Display: 1 단계, 이미지 3개 중 3개
    • Using the iFixit opening tool, insert the corner under Vector's golden side panel and lightly twist.
    • Repeat this step on the other side.
    • The panel should pop off without much force.
  2. Anki Vector LCD Facial Display Replacement: 2 단계, 이미지 3개 중 1개 Anki Vector LCD Facial Display Replacement: 2 단계, 이미지 3개 중 2개 Anki Vector LCD Facial Display Replacement: 2 단계, 이미지 3개 중 3개
    • Insert the corner of the square end of the spudger under the side plate above the partially visible screw.
    • Lightly turn the spudger to separate the plate from Vector's head.
    • Work the spudger around the plate until it comes off.
    • Repeat this step on the the other side.
  3. Anki Vector LCD Facial Display Replacement: 3 단계, 이미지 2개 중 1개 Anki Vector LCD Facial Display Replacement: 3 단계, 이미지 2개 중 2개
    • Using a Phillips #0 screwdriver, unscrew the two 2 mm screws on the side of Vector's head.
    • Repeat this step on the opposite side.
  4. Anki Vector LCD Facial Display Replacement: 4 단계, 이미지 2개 중 1개 Anki Vector LCD Facial Display Replacement: 4 단계, 이미지 2개 중 2개
    • Pull apart Vector's head. It should separate down the middle.
    • Remove the screen protector by gently pulling it free from the two face halves.
  5. Anki Vector LCD Facial Display Replacement: 5 단계, 이미지 3개 중 1개 Anki Vector LCD Facial Display Replacement: 5 단계, 이미지 3개 중 2개 Anki Vector LCD Facial Display Replacement: 5 단계, 이미지 3개 중 3개
    • Using your thumb and index finger, unplug the display from the plug in Vector's neck.
    • Pull the LCD and speaker assembly from Vector's head.
    • There is a very thin insulating rubber sheet located at the base of the screen. Be careful not to tear it when removing the display.
결론
다른 8명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Shay Takei
회원 가입일: 04/16/19
1,777 평판
안내서 5개를 작성함
Cal Poly, Team S2-G6, Maness Spring 2019 Cal Poly, Team S2-G6, Maness Spring 2019 회원
CPSU-MANESS-S19S2G6
4 회원들
안내서 10개를 작성함
26가이드 댓글
Any idea where to get the proper displays ?
Holger Brueckner - 답글
xenojin - 답글
This is great information, but where can I buy the display?
Jackie Fischvogt - 답글
yeah I can’t find it anywhere.
Joel Choi -
Does anyone have a line on display parts source?
warren williams - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 35
지난 30일: 131
전체 시간: 12,207
