주요 콘텐츠로 건너뛰기
Answering Machine Speaker Replacement
필요한 것
  1. Answering Machine Speaker Replacement, Base: 1 단계, 이미지 1/1
    • Turn the base over. You will see four 11mm Phillips #0 screws, one in each corner.
    • Use a screwdriver to remove all four 11mm Phillips #0 screws.
  2. Answering Machine Speaker Replacement: 2 단계, 이미지 1/2 Answering Machine Speaker Replacement: 2 단계, 이미지 2/2
    • Locate an easy seam for entry and insert the metal spudger to separate the plastic. Use the spudger in multiple places if necessary.
    • Opening the base may require exerting significant force as it is bound together tightly. This step can be dangerous.
    • The spudger is designed to make this step easier.
  3. Answering Machine Speaker Replacement, Answering Machine Speaker: 3 단계, 이미지 1/2 Answering Machine Speaker Replacement, Answering Machine Speaker: 3 단계, 이미지 2/2
    • Locate the speaker at the top left of the base as pictured. It is the silver, conical component. Two 7mm Phillips #0 screws hold the speaker in place.
    • Use a screwdriver to remove the two 7mm Phillips #0 screws.
  4. Answering Machine Speaker Replacement: 4 단계, 이미지 1/1
    • Finish speaker removal by cutting both the black and red wires.
  5. Answering Machine Speaker Replacement: 5 단계, 이미지 1/1
결론
Troy Chester
회원 가입일: 09/29/16
66 평판
안내서 1개 작성함
IUPUI, Team 3-3, Harley Fall 2016 IUPUI, Team 3-3, Harley Fall 2016 회원
IUPUI-HARLEY-F16S3G3
4 회원들
안내서 17개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 16
전체 시간: 644
