소개
Is the speaker on your answering machine not working well? This is the guide for you!
필요한 것
Locate the speaker at the top left of the base as pictured. It is the silver, conical component. Two 7mm Phillips #0 screws hold the speaker in place.
Use a screwdriver to remove the two 7mm Phillips #0 screws.
Solder your replacement speaker into the circuit. For assistance with soldering check out the iFixit Solder and Desolder Guide.
거의 끝나갑니다!
결론
