주요 콘텐츠로 건너뛰기
Apalus Digital Hair Straightening Brush Buttons Replacement
필요한 것
  1. Apalus Digital Hair Straightening Brush Buttons Replacement, Buttons on the side of the brush: 1 단계, 이미지 1/1
    • Remove the seven 5mm Phillips #1 screws on the comb-side of the brush.
  2. Apalus Digital Hair Straightening Brush Buttons Replacement: 2 단계, 이미지 1/1
    • Now that the screws are taken out, remove the backside of the comb.
  3. Apalus Digital Hair Straightening Brush Buttons Replacement: 3 단계, 이미지 1/1
    • Unplug the power cord from the insert inside of the brush.
    • Be careful not to tug on the wires. Hold the insert when removing the power cord.
  4. Apalus Digital Hair Straightening Brush Buttons Replacement: 4 단계, 이미지 1/1
    • Remove the circuit board and heating element from the handle.
    • This will make it easier to work on for later steps.
  5. Apalus Digital Hair Straightening Brush Buttons Replacement: 5 단계, 이미지 1/1
    • Locate the three buttons on the bottom side of the circuit board.
  6. Apalus Digital Hair Straightening Brush Buttons Replacement: 6 단계, 이미지 1/1
    • Each button is soldered in four places on the circuit board. Using the soldering tool, melt each of these four points and remove the dysfunctional buttons.
    • You may have to bend the dark red capacitor out of the way to reach the soldering points.
    • Soldering Technique Guide
  7. Apalus Digital Hair Straightening Brush Buttons Replacement: 7 단계, 이미지 1/1
    • Now that the dysfunctional buttons are removed, use a soldering tool and solder to install the new buttons on the circuit board.
    • Solder at the same four points as when previously melting these points to remove the buttons.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Aaron Brysch
회원 가입일: 11/06/17
231 평판
안내서 2개 작성하였습니다
IUPUI, Team S1-G3, Harley Fall 2017 IUPUI, Team S1-G3, Harley Fall 2017 회원
IUPUI-HARLEY-F17S1G3
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 24
전체 시간: 668
