주요 콘텐츠로 건너뛰기
Apalus Digital Hair Straightening Brush Heating Element Replacement
필요한 것
  1. Apalus Digital Hair Straightening Brush Heating Element Replacement, Heating Element: 1 단계, 이미지 1/1
    • Remove the seven 5mm Phillips #1 screws on the comb-side of the brush.
  2. Apalus Digital Hair Straightening Brush Heating Element Replacement: 2 단계, 이미지 1/1
    • Turn comb over so the bristles are facing down.
    • Remove backside of the comb and place aside.
  3. Apalus Digital Hair Straightening Brush Heating Element Replacement: 3 단계, 이미지 1/1
    • Unplug the power cord from the connector inside of the brush.
  4. Apalus Digital Hair Straightening Brush Heating Element Replacement: 4 단계, 이미지 1/1
    • Remove the circuit board and heating element from the handle.
    • This will provide easy access to the necessary components.
  5. Apalus Digital Hair Straightening Brush Heating Element Replacement: 5 단계, 이미지 1/1
    • Remove the four 6mm Phillips #2 screws holding the heat shield onto the back side of the bristles.
  6. Apalus Digital Hair Straightening Brush Heating Element Replacement: 6 단계, 이미지 1/1
    • There are 4 solder points of the heating element located on the LCD side of the circuit board.
    • Desolder these four connections using a soldering iron.
    • Note which wires go to each of the connection points.
    • Soldering Technique Guide
  7. Apalus Digital Hair Straightening Brush Heating Element Replacement: 7 단계, 이미지 1/1
    • Solder the new heating element to the same connection points as they were removed from.
결론
Aaron Brysch
회원 가입일: 11/06/17
231 평판
안내서 2개 작성하였습니다
IUPUI, Team S1-G3, Harley Fall 2017 IUPUI, Team S1-G3, Harley Fall 2017 회원
IUPUI-HARLEY-F17S1G3
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 15
전체 시간: 2,189
