이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Cut the wire at a length comfortable for the headphone user (preferable close to the old jack plug).
Using a wire stripper, remove about 1-2 cm of insulation from the end of the wire.
Seperate each wire from each other.
Make sure to have 6 different wires: Red, Green, Gold, Red-Green, Gold-Green, Red-Gold
Burn off the insulating wax from the signal carrying wires with a lighter and/or use a knife to rub it off.
Solder the wires to poles on the jack as outlined in the steps below. Poles are shown in the first picture segmented by the color boxes. For proper soldering technique please use: iFixit Soldering Guide
The first pole (Marked with the red box) is grounded. Solder on the green-gold, red-gold, and red-green wires. The third picture refers to this step.
The second pole (Marked with the orange box) is for the right earbud. Solder on the red wire.
The third pole (Marked with the yellow box) is for the left earbud. Solder on the green wire.
Finally, the fourth pole (Marked with the green box) that is not connected to the rest is for the mic. Solder on the gold wire.
다른 5명이 해당 안내서를 완성하였습니다.
댓글 6개
Step 5 wrong! The Mic is the red&green cable and the gold cable doesn't exist in my earpods. There is a 6th cord however which is a nylon like support cord.
The gold wire is hidden inside the red-green wire. Unwind the red-green to find it. The gold is the mic, the red-green is the mic ground. If you use the original jack (cut away the moulded on white plastic) you can use a multimeter to find the mic connection which is on the other side of the ground connection. Thanks for the page. Good luck
Jonathan -
I recycled the same factory jack and identified the poles with a multimeter. I followed the same instructions. Their volume is lower than usual. Thanks for the page.
This article was pretty useful for me. Great thanks to the author and also people who commented here.
