필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Typical Apple product packaging. Simple yet elegant
Backside of the package
Bottom of the package describes the adapter as a A1749
Again, nice packaging for the adapter.
The total length of the adapter is 3 1/8 inches or 8cm. One side with the lightning connector and the other end is the 3.5mm headphone jack.
Checked to see if there was any way to remove the outside of the adapter by slipping some thin tools in between. No way on that.
This is the business end that requires the removal of the covering.
The only way to do that is by cutting into it. Using a good scalpel does cut it with relative ease.
Cutting length wise on one side
as well as the opposite site
Then flipping the two halves that were created by the cuts.
This makes for an easy removal.
The next thing to be removed is the ground shield.
Using a pair of small side cutters that shield is easily removed as well.
Just a matter of using the cutters on one end
and rolling it around the connector.
This shows the destructive nature of this teardown
The connector is now left with another plastic covering.
Luckily the removal of the ground shield seems to have open slots lengthwise in the plastic covering.
Using these slots, the plastic needs to be carefully pulled away from the circuit board.
Here is the business end with the cover removed.
This side shows what appears to be the DAC inside this adapter
Close-up of the circuit board shows Apple's fascination with adhesive and other sticky substances. Both sides of the circuit board are covered with it.
A bit more of a close up of one side
as well as the other. As more information becomes available about the DAC this teardown will be edited to reflect those.
Here are the markings on the DAC 338S00140 A0SM1624 TW
Carefully slice down the headphone jack connector with a sharp knife, being careful to not cut yourself.
Repairability score: 0 out of 10
The device is clearly not meant to be opened or repaired in any way.
It is impossible to open the adapter without destroying it.
댓글 32개
There seem to be a lot more wires than necessary going to the 3.5mm connector. By my count there appear to be 7 or 8 discrete wires?
At most there should be 4, TRRS, and maybe a shield ground. How are the other wires used here?
Mac 128 excellent question and I will try and take the jack end off as well asap. There is a total of 7 wires....
Perhaps it supports both standard pinout methods for mics/remotes, rather than just Apples flipped data/ground pin standard?
tipoo -
I am currently looking into modyfying an Apple TRRS connector so I can take some readings on what is what and how it may function. Only hold-up is that I do work for a living:-) so time is always an issue.
Mac 128 mystery already solved. Check this teardown by Mason Dowell Apple Earphones with Remote and Mic (Lightning Edition) Teardown. It'll explain what each wire does.
