소개
During this guide you will need some solder skills to repair the product. If you don't have any experiences in soldering, take a look at the How to Solder and Desolder Connections guide. Make sure you have all the tools that's needed to desolder en solder. Be aware of the fumes—do this in a well ventilated room!
필요한 것
Unscrew the four Phillips screws on the backside of the docking system.
이 단계에 사용된 도구:Desoldering Pump$3.99
Trigger the desoldering pump before heating the solder.
거의 끝나갑니다!
Om het apparaat weer te monteren, volg je deze instructies in omgekeerde volgorde vanaf stap 7.
결론
