주요 콘텐츠로 건너뛰기
Apple iPod Hi-Fi Batteries Replacement
필요한 것
  1. Apple iPod Hi-Fi Batteries Replacement, Batteries: 1 단계, 이미지 1/1
    • Put your coin in the battery lock on the back of the the Hi-Fi. Turn the coin to the left to release the battery panel.
    • Remove the battery panel with your hands.
    • You can also use a metal spudger or flathead screwdriver to open the battery lock instead of a coin.
  2. Apple iPod Hi-Fi Batteries Replacement: 2 단계, 이미지 1/1
    • Remove the six D batteries from the device.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Timothy Scheuermann
회원 가입일: 04/18/18
710 평판
안내서 3개 작성하였습니다
Cal Poly, Team S16-G1, Livingston Spring 2018 Cal Poly, Team S16-G1, Livingston Spring 2018 회원
CPSU-LIVINGSTON-S18S16G1
5 회원들
안내서 16개 작성하였습니다
댓글 3개
good day.  Does the column charge the batteries when it is plugged in?
pay4e4ek777 - 답글
Nope, the hifi will not charge any batteries that are installed.
Josh Calvetti -
Hello, I realize these comments/texts are a bit old (2019) however, I have an Apple Speaker unit from 2006 that is practically new with very little usage but stopped working due to purchasing a Bluetooth adaptor and inserting it in the rear (Audio in) jack. It had been working “great” with the Bluetooth and my iPhone for a while until the speaker unit ceased to function-turn back on (no power). Can you kindly assist in assessing-determining what might have gone wrong and what would be required to fix this problem. Many thanks ahead. Look forward to your reply.
Roosevelt Adrianza - 답글
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 26
30일 전: 103
전체 시간: 4,504
