주요 콘텐츠로 건너뛰기
Arlo Ultra 2 Camera Lens Replacement
필요한 것
  1. Arlo Ultra 2 Camera Lens Replacement, Battery: 1 단계, 이미지 2개 중 1개 Arlo Ultra 2 Camera Lens Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Press the button on the bottom of the camera to release the case.
    • Pull the white case off of camera.
  2. Arlo Ultra 2 Camera Lens Replacement: 2 단계, 이미지 1개 중 1개
    • Pull the white cube shaped battery from the back to remove it from camera.
  3. Arlo Ultra 2 Camera Lens Replacement, Speaker: 3 단계, 이미지 2개 중 1개 Arlo Ultra 2 Camera Lens Replacement, Speaker: 3 단계, 이미지 2개 중 2개
    • Use a Phillips #0 screwdriver to remove the four 20.0 mm screws from the battery cavity. They are found in each corner.
  4. Arlo Ultra 2 Camera Lens Replacement: 4 단계, 이미지 2개 중 1개 Arlo Ultra 2 Camera Lens Replacement: 4 단계, 이미지 2개 중 2개
    • Using the spudger, loosen and remove the camera faceplate.
  5. Arlo Ultra 2 Camera Lens Replacement: 5 단계, 이미지 2개 중 1개 Arlo Ultra 2 Camera Lens Replacement: 5 단계, 이미지 2개 중 2개
    • Using the spudger, loosen and remove the back casing to expose the camera hardware.
  6. Arlo Ultra 2 Camera Lens Replacement: 6 단계, 이미지 2개 중 1개 Arlo Ultra 2 Camera Lens Replacement: 6 단계, 이미지 2개 중 2개
    • Very gently, pry the circuit boards apart from the white connector, removing the upper circuit board.
  7. Arlo Ultra 2 Camera Lens Replacement: 7 단계, 이미지 2개 중 1개 Arlo Ultra 2 Camera Lens Replacement: 7 단계, 이미지 2개 중 2개
    • Use a Phillips #00 screwdriver to remove two 5.0 mm screws from the metal bracket.
    • Use a spudger to separate the long metal bracket.
    • There is an arrow etched into the bracket. It points towards the top of the camera. This is important when reassembling the camera.
  8. Arlo Ultra 2 Camera Lens Replacement: 8 단계, 이미지 3개 중 1개 Arlo Ultra 2 Camera Lens Replacement: 8 단계, 이미지 3개 중 2개 Arlo Ultra 2 Camera Lens Replacement: 8 단계, 이미지 3개 중 3개
    • Use the tip of a spudger or your fingernail to flip up the small locking flap on each ZIF connector. Then, you can safely pull the cables out.
    • Be sure to pry up on the hinged flap, not the connector socket.
  9. Arlo Ultra 2 Camera Lens Replacement: 9 단계, 이미지 2개 중 1개 Arlo Ultra 2 Camera Lens Replacement: 9 단계, 이미지 2개 중 2개
    • Use a spudger to carefully push on each side of the speaker cable connector until it's out of its socket.
  10. Arlo Ultra 2 Camera Lens Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the small green circuit board.
  11. Arlo Ultra 2 Camera Lens Replacement: 11 단계, 이미지 3개 중 1개 Arlo Ultra 2 Camera Lens Replacement: 11 단계, 이미지 3개 중 2개 Arlo Ultra 2 Camera Lens Replacement: 11 단계, 이미지 3개 중 3개
    • Feed the speaker cable through the opening to remove the speaker.
  12. Arlo Ultra 2 Camera Lens Replacement, Camera Lens: 12 단계, 이미지 3개 중 1개 Arlo Ultra 2 Camera Lens Replacement, Camera Lens: 12 단계, 이미지 3개 중 2개 Arlo Ultra 2 Camera Lens Replacement, Camera Lens: 12 단계, 이미지 3개 중 3개
    • Use a Phillips #00 screwdriver to remove the two 5.0 mm screws from both sides of the metal plate.
    • Pry the metal plate away from circuit board underneath.
    • There is a small amount of blue putty in between the metal plate and the circuit board.
  13. Arlo Ultra 2 Camera Lens Replacement: 13 단계, 이미지 3개 중 1개 Arlo Ultra 2 Camera Lens Replacement: 13 단계, 이미지 3개 중 2개 Arlo Ultra 2 Camera Lens Replacement: 13 단계, 이미지 3개 중 3개
    • Use a spudger to remove the entire green circuit board with lens attached.
  14. Arlo Ultra 2 Camera Lens Replacement: 14 단계, 이미지 3개 중 1개 Arlo Ultra 2 Camera Lens Replacement: 14 단계, 이미지 3개 중 2개 Arlo Ultra 2 Camera Lens Replacement: 14 단계, 이미지 3개 중 3개
    • Use a Phillips #00 screwdriver to remove three black 5.0 mm screws from back of the circuit board.
    • Separate the lens from the circuit board.
    • There is a small cord connecting the lens and circuit board.
  15. Arlo Ultra 2 Camera Lens Replacement: 15 단계, 이미지 2개 중 1개 Arlo Ultra 2 Camera Lens Replacement: 15 단계, 이미지 2개 중 2개
    • Use a spudger to carefully push on each side of the white cable connector to remove it from the socket and separate the camera lens from the board.
  16. Arlo Ultra 2 Camera Lens Replacement: 16 단계, 이미지 3개 중 1개 Arlo Ultra 2 Camera Lens Replacement: 16 단계, 이미지 3개 중 2개 Arlo Ultra 2 Camera Lens Replacement: 16 단계, 이미지 3개 중 3개
    • Use a Phillips #00 screwdriver to remove the two 4.0 mm screws from the side of the lens body.
  17. Arlo Ultra 2 Camera Lens Replacement: 17 단계, 이미지 3개 중 1개 Arlo Ultra 2 Camera Lens Replacement: 17 단계, 이미지 3개 중 2개 Arlo Ultra 2 Camera Lens Replacement: 17 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use the blunt tweezers to remove the focus motor control insert from the main lens body.
결론
작성자
4다른 기여자 명과 함께
Xavier Feaster-Rivera
회원 가입일: 01/23/23
449 평판
안내서 2개를 작성함
7가이드 댓글
Any ideas on where to get the lens ordered?
Jerald Buechler - 답글
I called Arlo and they said they don’t sell a replacement. I couldn’t find it anywhere online either. Does anybody know where to get a replacement?
Barry Bonds - 답글
My was badly scratched and I would like to replace the lens but I can't find any arlo lenses for sale. Plenty other ones but not arlo one.
Karol jar - 답글
Has anyon found where to buy a replacement lens? Mine is cracked and unusable without a new lens.
Digit Holder - 답글
My Arlo ultra lens fell out and smashed whilst swapping out the battery, the inertia from the tap dislodged the poorly fix lens, now I cant find a replacement
Paul Heslin - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 15
지난 30일: 85
전체 시간: 1,976
