주요 콘텐츠로 건너뛰기
Arlo Ultra 2 Motion Sensor Replacement
필요한 것
  1. Arlo Ultra 2 Motion Sensor Replacement, Battery: 1 단계, 이미지 2개 중 1개 Arlo Ultra 2 Motion Sensor Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Press the button on the bottom of the camera to release the case.
    • Pull the white case off of camera.
  2. Arlo Ultra 2 Motion Sensor Replacement: 2 단계, 이미지 1개 중 1개
    • Pull the white cube shaped battery from the back to remove it from camera.
  3. Arlo Ultra 2 Motion Sensor Replacement, Speaker: 3 단계, 이미지 2개 중 1개 Arlo Ultra 2 Motion Sensor Replacement, Speaker: 3 단계, 이미지 2개 중 2개
    • Use a Phillips #0 screwdriver to remove the four 20.0 mm screws from the battery cavity. They are found in each corner.
  4. Arlo Ultra 2 Motion Sensor Replacement: 4 단계, 이미지 2개 중 1개 Arlo Ultra 2 Motion Sensor Replacement: 4 단계, 이미지 2개 중 2개
    • Using the spudger, loosen and remove the camera faceplate.
  5. Arlo Ultra 2 Motion Sensor Replacement: 5 단계, 이미지 2개 중 1개 Arlo Ultra 2 Motion Sensor Replacement: 5 단계, 이미지 2개 중 2개
    • Using the spudger, loosen and remove the back casing to expose the camera hardware.
  6. Arlo Ultra 2 Motion Sensor Replacement: 6 단계, 이미지 2개 중 1개 Arlo Ultra 2 Motion Sensor Replacement: 6 단계, 이미지 2개 중 2개
    • Very gently, pry the circuit boards apart from the white connector, removing the upper circuit board.
  7. Arlo Ultra 2 Motion Sensor Replacement: 7 단계, 이미지 2개 중 1개 Arlo Ultra 2 Motion Sensor Replacement: 7 단계, 이미지 2개 중 2개
    • Use a Phillips #00 screwdriver to remove two 5.0 mm screws from the metal bracket.
    • Use a spudger to separate the long metal bracket.
    • There is an arrow etched into the bracket. It points towards the top of the camera. This is important when reassembling the camera.
  8. Arlo Ultra 2 Motion Sensor Replacement: 8 단계, 이미지 3개 중 1개 Arlo Ultra 2 Motion Sensor Replacement: 8 단계, 이미지 3개 중 2개 Arlo Ultra 2 Motion Sensor Replacement: 8 단계, 이미지 3개 중 3개
    • Use the tip of a spudger or your fingernail to flip up the small locking flap on each ZIF connector. Then, you can safely pull the cables out.
    • Be sure to pry up on the hinged flap, not the connector socket.
  9. Arlo Ultra 2 Motion Sensor Replacement: 9 단계, 이미지 2개 중 1개 Arlo Ultra 2 Motion Sensor Replacement: 9 단계, 이미지 2개 중 2개
    • Use a spudger to carefully push on each side of the speaker cable connector until it's out of its socket.
  10. Arlo Ultra 2 Motion Sensor Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the small green circuit board.
  11. Arlo Ultra 2 Motion Sensor Replacement: 11 단계, 이미지 3개 중 1개 Arlo Ultra 2 Motion Sensor Replacement: 11 단계, 이미지 3개 중 2개 Arlo Ultra 2 Motion Sensor Replacement: 11 단계, 이미지 3개 중 3개
    • Feed the speaker cable through the opening to remove the speaker.
  12. Arlo Ultra 2 Motion Sensor Replacement, Motion Sensor: 12 단계, 이미지 3개 중 1개 Arlo Ultra 2 Motion Sensor Replacement, Motion Sensor: 12 단계, 이미지 3개 중 2개 Arlo Ultra 2 Motion Sensor Replacement, Motion Sensor: 12 단계, 이미지 3개 중 3개
    • Use a Phillips #00 screwdriver to remove the two 5.0 mm screws from the metal plate.
    • Pry the plate away from the circuit board underneath.
  13. Arlo Ultra 2 Motion Sensor Replacement: 13 단계, 이미지 3개 중 1개 Arlo Ultra 2 Motion Sensor Replacement: 13 단계, 이미지 3개 중 2개 Arlo Ultra 2 Motion Sensor Replacement: 13 단계, 이미지 3개 중 3개
    • Use a spudger to remove the circuit board with the lens attached.
  14. Arlo Ultra 2 Motion Sensor Replacement: 14 단계, 이미지 3개 중 1개 Arlo Ultra 2 Motion Sensor Replacement: 14 단계, 이미지 3개 중 2개 Arlo Ultra 2 Motion Sensor Replacement: 14 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use blunt tweezers to pull up the heat-resistant tape.
    • Pull the heat-resistant tape through to the front of the camera.
  15. Arlo Ultra 2 Motion Sensor Replacement: 15 단계, 이미지 3개 중 1개 Arlo Ultra 2 Motion Sensor Replacement: 15 단계, 이미지 3개 중 2개 Arlo Ultra 2 Motion Sensor Replacement: 15 단계, 이미지 3개 중 3개
    • Place the tip of your spudger under the edge of the motion sensor connector, and pry the connector straight up from its socket.
  16. Arlo Ultra 2 Motion Sensor Replacement: 16 단계, 이미지 2개 중 1개 Arlo Ultra 2 Motion Sensor Replacement: 16 단계, 이미지 2개 중 2개
    • Use a spudger to remove the motion sensors from the housing.
    • Finish removing the entire motion sensor and microphone electric tape.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Madeleine Kennedy
회원 가입일: 01/23/23
319 평판
안내서 2개를 작성함
2가이드 댓글
I wonder if you might have any insight on why these are so failure prone? I have had this happen twice since buying these cameras a little over a year ago. This would seem to be a simple part, kind of like an led bulb, typically they just don’t fail before other parts of the device have just gotten old and broken down. I know others have been having this exact issue also.
Ash Miller - 답글
Hello could you provide any information on part number and where to buy replacement motion sensors?
TIA
Richard Moyden - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 26
전체 시간: 558
