주요 콘텐츠로 건너뛰기
Astro A50 (2019) Battery Replacement
필요한 것
  1. Astro A50 (2019) Battery Replacement, Battery: 1 단계, 이미지 1/2 Astro A50 (2019) Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Remove the right side ear cushion by pulling toward you on the top tab.
  2. Astro A50 (2019) Battery Replacement: 2 단계, 이미지 1/3 Astro A50 (2019) Battery Replacement: 2 단계, 이미지 2/3 Astro A50 (2019) Battery Replacement: 2 단계, 이미지 3/3
    • Remove the speaker filter by using a prying tool and peeling it off.
    • Work your way around the filter until it comes off.
  3. Astro A50 (2019) Battery Replacement: 3 단계, 이미지 1/3 Astro A50 (2019) Battery Replacement: 3 단계, 이미지 2/3 Astro A50 (2019) Battery Replacement: 3 단계, 이미지 3/3
    • Remove all four 1.5 mm screws using the Phillips #00 screwdriver.
    • Be careful not to lift the speaker too quickly or too forcefully to prevent the wires from being pulled out of their connections.
  4. Astro A50 (2019) Battery Replacement: 4 단계, 이미지 1/3 Astro A50 (2019) Battery Replacement: 4 단계, 이미지 2/3 Astro A50 (2019) Battery Replacement: 4 단계, 이미지 3/3
    • Remove all four 1.5 mm screws holding the motherboard using the Phillips #00 screwdriver.
    • Unplug the battery by pulling the plug.
  5. Astro A50 (2019) Battery Replacement: 5 단계, 이미지 1/2 Astro A50 (2019) Battery Replacement: 5 단계, 이미지 2/2
    • Remove the old battery with a plastic opening tool.
    • Be careful to not puncture the battery or fold it.
결론
For optimal performance, after completing this guide, calibrate your newly installed battery.
다른 2명이 해당 안내서를 완성하였습니다.
Bryan Ambrocio-Gonzalez
회원 가입일: 10/05/21
191 평판
안내서 1개 작성함
CSU Los Angeles, Team 11-6, Grodsky Fall 2021 CSU Los Angeles, Team 11-6, Grodsky Fall 2021 회원
CSULA-GRODSKY-F21S11G6
2 회원들
안내서 3개 작성하였습니다
댓글 5개
Where did you source the battery for this? Do you have the part number at least? Astro doesn't sell them.
Thomas Garcia - 답글
I am also looking for this without having to get them from china as it will take 4 to 6 weeks to get it. Any local source for this battery?
billy7183 - 답글
I had to order from China, only batteries that are held domestically I could find were for the gen3/solder only and not the connector style
Luft -
For those with a gen3 a50, the battery is mounted slightly different, you don't need to remove the PCB, just pinch the black tabs holding the outer cover on. See here: https://imgur.com/a/m2Nv2Ze
Wouter V - 답글
I performed this battery replacement. I sourced a new battery from another new A50 Gen 4 that was firmware bricked.
I’m having an issue charging the new battery with the base station. The headset does not seem to accept a charge from the base station however it will charge via a micro USB cable plugged into a usb wall brick.
I believe the issue is related to the battery not being calibrated to the old headset. Any ideas?
William Patterson - 답글
댓글 쓰기
조회 통계:
24 시간 전: 29
7일 전: 144
30일 전: 560
전체 시간: 9,171
