주요 콘텐츠로 건너뛰기
Astro A50 (2019) Battery Replacement
필요한 것
  1. Astro A50 (2019) Battery Replacement, Battery: 1 단계, 이미지 2개 중 1개 Astro A50 (2019) Battery Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Remove the right side ear cushion by pulling toward you on the top tab.
  2. Astro A50 (2019) Battery Replacement: 2 단계, 이미지 3개 중 1개 Astro A50 (2019) Battery Replacement: 2 단계, 이미지 3개 중 2개 Astro A50 (2019) Battery Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the speaker filter by using a prying tool and peeling it off.
    • Work your way around the filter until it comes off.
  3. Astro A50 (2019) Battery Replacement: 3 단계, 이미지 3개 중 1개 Astro A50 (2019) Battery Replacement: 3 단계, 이미지 3개 중 2개 Astro A50 (2019) Battery Replacement: 3 단계, 이미지 3개 중 3개
    • Remove all four 1.5 mm screws using the Phillips #00 screwdriver.
    • Be careful not to lift the speaker too quickly or too forcefully to prevent the wires from being pulled out of their connections.
  4. Astro A50 (2019) Battery Replacement: 4 단계, 이미지 3개 중 1개 Astro A50 (2019) Battery Replacement: 4 단계, 이미지 3개 중 2개 Astro A50 (2019) Battery Replacement: 4 단계, 이미지 3개 중 3개
    • Remove all four 1.5 mm screws holding the motherboard using the Phillips #00 screwdriver.
    • Unplug the battery by pulling the plug.
  5. Astro A50 (2019) Battery Replacement: 5 단계, 이미지 2개 중 1개 Astro A50 (2019) Battery Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the old battery with a plastic opening tool.
    • Be careful to not puncture the battery or fold it.
결론
For optimal performance, after completing this guide, calibrate your newly installed battery.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Bryan Ambrocio-Gonzalez
회원 가입일: 10/05/21
233 평판
안내서 1개를 작성함
CSU Los Angeles, Team 11-6, Grodsky Fall 2021 CSU Los Angeles, Team 11-6, Grodsky Fall 2021 회원
CSULA-GRODSKY-F21S11G6
2 회원들
안내서 4개를 작성함
8가이드 댓글
Where did you source the battery for this? Do you have the part number at least? Astro doesn't sell them.
Thomas Garcia - 답글
I am also looking for this without having to get them from china as it will take 4 to 6 weeks to get it. Any local source for this battery?
billy7183 - 답글
I had to order from China, only batteries that are held domestically I could find were for the gen3/solder only and not the connector style
Luft -
For those with a gen3 a50, the battery is mounted slightly different, you don't need to remove the PCB, just pinch the black tabs holding the outer cover on. See here: https://imgur.com/a/m2Nv2Ze
Wouter V - 답글
I performed this battery replacement. I sourced a new battery from another new A50 Gen 4 that was firmware bricked.
I’m having an issue charging the new battery with the base station. The headset does not seem to accept a charge from the base station however it will charge via a micro USB cable plugged into a usb wall brick.
I believe the issue is related to the battery not being calibrated to the old headset. Any ideas?
William Patterson - 답글
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 92
지난 30일: 554
전체 시간: 20,661
