주요 콘텐츠로 건너뛰기
Astro A50 2016 Headset Motherboard Replacement
필요한 것
  1. Astro A50 2016 Headset Motherboard Replacement, Headset Speakers: 1 단계, 이미지 2개 중 1개 Astro A50 2016 Headset Motherboard Replacement, Headset Speakers: 1 단계, 이미지 2개 중 2개
    • Remove the magnetic ear pads by gently pulling up away from the head set.
  2. Astro A50 2016 Headset Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Squeeze the plastic opening tool between the black plastic and foam pad on non mic side and then pry upwards to remove the felt pads covering the speaker.
  3. Astro A50 2016 Headset Motherboard Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the four 6mm Phillips 1 screws.
  4. Astro A50 2016 Headset Motherboard Replacement: 4 단계, 이미지 1개 중 1개
    • Lift the speaker module up off the device.
  5. Astro A50 2016 Headset Motherboard Replacement, Headset Motherboard: 5 단계, 이미지 1개 중 1개
  6. Astro A50 2016 Headset Motherboard Replacement: 6 단계, 이미지 2개 중 1개 Astro A50 2016 Headset Motherboard Replacement: 6 단계, 이미지 2개 중 2개
    • Use a soldering iron to desolder the black and yellow wires from the two metal plates near the bottom of the device.
    • Use a soldering iron to desolder the 13 wires in rows along the left and bottom sides of the headset motherboard.
    • 연결부 납땜 및 납제거 방법
  7. Astro A50 2016 Headset Motherboard Replacement: 7 단계, 이미지 1개 중 1개
    • Use the plastic opening tool to pry off the black tape covering the gray wires
  8. Astro A50 2016 Headset Motherboard Replacement: 8 단계, 이미지 1개 중 1개
    • Lift the motherboard out of the headset and gently disconnect the gray wires from the motherboard.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Brian Menard
회원 가입일: 10/01/17
306 평판
안내서 1개를 작성함
Cal Poly, Team S15-G1, Livingston Fall 2017 Cal Poly, Team S15-G1, Livingston Fall 2017 회원
CPSU-LIVINGSTON-F17S15G1
3 회원들
안내서 10개를 작성함
댓글 2개
Any chance I could get the E250336. USB board part from you guys? I need one.
Theron Miller - 답글
I am having a very tough time finding this Part online. Thanks!
Theron Miller - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 43
전체 시간: 4,326
