주요 콘텐츠로 건너뛰기
Asus CM1745 Heatsink Replacement
필요한 것
  1. Asus CM1745 Heatsink Replacement, Heatsink: 1 단계, 이미지 2개 중 1개 Asus CM1745 Heatsink Replacement, Heatsink: 1 단계, 이미지 2개 중 2개
    • Remove the sidepanel by unscrewing the two screws fastening the panel on the rear. Once unscrewed, slide the panel towards the rear until it releases then lift away.
  2. Asus CM1745 Heatsink Replacement: 2 단계, 이미지 2개 중 1개 Asus CM1745 Heatsink Replacement: 2 단계, 이미지 2개 중 2개
    • Unplug the CPU fan connector from the motherboard.
    • Then open the latch under the CPU fan and unhook the metal fasteners.
    • Lift the CPU heatsink and cable off of the CPU carefully.
  3. Asus CM1745 Heatsink Replacement: 3 단계, 이미지 3개 중 1개 Asus CM1745 Heatsink Replacement: 3 단계, 이미지 3개 중 2개 Asus CM1745 Heatsink Replacement: 3 단계, 이미지 3개 중 3개
    • Clean both the CPU top and the heatsink bottom by slightly moistening a paper towel with rubbing alcohol and rubbing lightly.
    • Grab your thermal paste and put a pea-sized amount in the middle of the CPU top.
    • Gently replace the heatsink on top of the CPU and re-lock the heatsink fasteners.
    • Replug the CPU Fan connector to the motherboard header.
    • Check out the How to Apply Thermal Paste guide for more details and best practices.
결론
Replug the computer and turn it on. If the fan spins, reattach the sidepanels and the replacement is complete.
작성자
4다른 기여자 명과 함께
TC Fowlar
회원 가입일: 10/30/19
836 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 11
지난 30일: 21
전체 시간: 1,036
