주요 콘텐츠로 건너뛰기
Asus Chromebook C101P Heat Sink Replacement
필요한 것
  1. Asus Chromebook C101P Heat Sink Replacement, Keyboard: 1 단계, 이미지 1/1
    • Flip the Chromebook so that the bottom is facing up.
    • Remove the nine T5 Torx screws.
  2. Asus Chromebook C101P Heat Sink Replacement: 2 단계, 이미지 1/1
    • Remove the four rubber grips on the bottom side of the Chromebook using an opening tool.
  3. Asus Chromebook C101P Heat Sink Replacement: 3 단계, 이미지 1/1
    • Remove the four black screws where the rubber grips were.
  4. Asus Chromebook C101P Heat Sink Replacement: 4 단계, 이미지 1/2 Asus Chromebook C101P Heat Sink Replacement: 4 단계, 이미지 2/2
    • Reorient the Chromebook so the right side is facing upwards.
    • Wedge an opening tool or spudger between the keyboard (upper case) and the lower case of the bottom portion of the Chromebook.
  5. Asus Chromebook C101P Heat Sink Replacement: 5 단계, 이미지 1/3 Asus Chromebook C101P Heat Sink Replacement: 5 단계, 이미지 2/3 Asus Chromebook C101P Heat Sink Replacement: 5 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Pull back the black lever on the base of the cable. While pulling back, take your tweezers and pull back on the large ribbon cable.
    • Pull back the black lever on the base of the cable. While pulling back, take your tweezers and pull back on the small ribbon cable.
    • Separate the keyboard from the rest of the laptop.
  6. Asus Chromebook C101P Heat Sink Replacement, Heat Sink: 6 단계, 이미지 1/2 Asus Chromebook C101P Heat Sink Replacement, Heat Sink: 6 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Detach the the screen cables from the motherboard using a pair of tweezers.
    • Peel off the tape or seal to easily remove the screen cables.
  7. Asus Chromebook C101P Heat Sink Replacement: 7 단계, 이미지 1/1
    • Flip up the black lever on the base of the small white ribbon cable. Remove the cable and set it aside.
  8. Asus Chromebook C101P Heat Sink Replacement: 8 단계, 이미지 1/1
    • Remove the nine Phillips #0 screws.
    • The 3 circles on the hand indicate that there are 3 more screws not visible in the photo.
    • Remove the battery cable if possible. Otherwise, gently flip the motherboard upside down to reveal the heat sink.
    • The motherboard may be hot. Be sure that you have left the Chromebook turned off for a few minutes.
  9. Asus Chromebook C101P Heat Sink Replacement: 9 단계, 이미지 1/2 Asus Chromebook C101P Heat Sink Replacement: 9 단계, 이미지 2/2
    • Remove the four Phillips #0 screws from the heat sink.
    • Detach the heat sink from the motherboard.
    • Detaching may provide a bit of resistance because of thermal paste.
    • When you are ready to apply the new heat sink, be sure to apply a small dab of thermal paste onto the CPU.
결론
Dan Sysopha
회원 가입일: 10/25/19
345 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S1-G2, O'Connell Fall 2019 UMass Dartmouth, Team S1-G2, O'Connell Fall 2019 회원
UMASSD-O'CONNELL-F19S1G2
2 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 14
전체 시간: 859
