필요한 것
Turn the power off and turn the netbook upside down.
Slide both battery catches together to release the battery.
Slide the battery out.
Remove the screws as necessary.
For top cover removing, only remove the 2 bottom screws.
The one short screw paterns to uper left screw hole directly on the PCB.
Remove the keyboard 4 screws on the bottom.
Use a Plastic Opening Tools to release the keyboard clips on the left and right side.
Peel off the protective tape at the bottom left corner.
Peel off the warranty void at the bottom right corner and remove the screw below.
Remove the 6 other screws.
다른 2명이 해당 안내서를 완성하였습니다.
