주요 콘텐츠로 건너뛰기
Asus Eee PC 1215N Top Cover (Touchpad) Replacement
필요한 것
  1. Asus Eee PC 1215N Top Cover (Touchpad) Replacement, Battery: 1 단계, 이미지 2개 중 1개 Asus Eee PC 1215N Top Cover (Touchpad) Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Turn the power off and turn the netbook upside down.
    • Slide both battery catches together to release the battery.
    • Slide the battery out.
  2. Asus Eee PC 1215N Top Cover (Touchpad) Replacement, RAM: 2 단계, 이미지 3개 중 1개 Asus Eee PC 1215N Top Cover (Touchpad) Replacement, RAM: 2 단계, 이미지 3개 중 2개 Asus Eee PC 1215N Top Cover (Touchpad) Replacement, RAM: 2 단계, 이미지 3개 중 3개
    • Locate the memory compartment.
    • Using a Plastic Opening Tools, remove the screw rubber cover.
    • Remove the screw.
  3. Asus Eee PC 1215N Top Cover (Touchpad) Replacement: 3 단계, 이미지 1개 중 1개
    • Use a Plastic Opening Tools near the screw hole to release the cover.
    • Remove the cover
  4. Asus Eee PC 1215N Top Cover (Touchpad) Replacement: 4 단계, 이미지 2개 중 1개 Asus Eee PC 1215N Top Cover (Touchpad) Replacement: 4 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Spudger
    $3.99
    • Using a Spudger, push both right and left metal clip to release one of the RAM module.
    • Slide out the RAM module.
    • Do the same with the second RAM module if necessary.
  5. Asus Eee PC 1215N Top Cover (Touchpad) Replacement, Top Cover (Touchpad): 5 단계, 이미지 1개 중 1개
    • Remove the screws as necessary.
    • For top cover removing, only remove the 2 bottom screws.
    • For Keyboard removing, remove all 4 screws.
    • The one short screw paterns to uper left screw hole directly on the PCB.
  6. Asus Eee PC 1215N Top Cover (Touchpad) Replacement: 6 단계, 이미지 3개 중 1개 Asus Eee PC 1215N Top Cover (Touchpad) Replacement: 6 단계, 이미지 3개 중 2개 Asus Eee PC 1215N Top Cover (Touchpad) Replacement: 6 단계, 이미지 3개 중 3개
    • Use a Plastic Opening Tools to release the top cover.
    • Start from the left side.
    • Go around on the bottom
    • Finish with the right side.
    • The top cover is still connected to the PCB with the touchpad ribbon. Handle it carefully.
  7. Asus Eee PC 1215N Top Cover (Touchpad) Replacement: 7 단계, 이미지 2개 중 1개 Asus Eee PC 1215N Top Cover (Touchpad) Replacement: 7 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Spudger
    $3.99
    • Carefully slide the top cover to the bottom in order to see the touchpad connector on the PCB.
    • Use a Spudger to slide the conector attachment black part and release the ribbon from the PCB.
    • Now you can remove the top cover
결론
작성자
1다른 기여자 명과 함께
Gaetan
회원 가입일: 12/26/12
9,613 평판
안내서 18개를 작성함
1가이드 댓글
Unrelated. My Asus VX-6 recently had the blue USB 3.0 ports stop working. Now the Ethernet connection is intermittent, goes away, come back, over and over again. Are those 3 ports on the right hand side part of the main board or separate boards?
paul poco - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 8
전체 시간: 2,837
