주요 콘텐츠로 건너뛰기
Asus G75VW-BHI7N07 USB Port Replacement
필요한 것
  1. Asus G75VW-BHI7N07 USB Port Replacement, USB Port: 1 단계, 이미지 1/3 Asus G75VW-BHI7N07 USB Port Replacement, USB Port: 1 단계, 이미지 2/3 Asus G75VW-BHI7N07 USB Port Replacement, USB Port: 1 단계, 이미지 3/3
    • Remove the screws around the back cover using a Phillips #1 screwdriver.
    • Take the back cover off using the opening tool.
  2. Asus G75VW-BHI7N07 USB Port Replacement: 2 단계, 이미지 1/3 Asus G75VW-BHI7N07 USB Port Replacement: 2 단계, 이미지 2/3 Asus G75VW-BHI7N07 USB Port Replacement: 2 단계, 이미지 3/3
    • Once you get rid of the back cover, spot all the screws marked ‘A’. There should be 10 in total.
    • Remove the battery using the slide release button.
    • This should expose 2 more ‘A’ marked screws.
    • Remove those using the same screwdriver.
  3. Asus G75VW-BHI7N07 USB Port Replacement: 3 단계, 이미지 1/2 Asus G75VW-BHI7N07 USB Port Replacement: 3 단계, 이미지 2/2
    • Using the opening tool, remove the disc drive cover.
    • Spot the 6 ‘B’ marked screws and remove them using the Phillips #1 screwdriver.
  4. Asus G75VW-BHI7N07 USB Port Replacement: 4 단계, 이미지 1/2 Asus G75VW-BHI7N07 USB Port Replacement: 4 단계, 이미지 2/2
    • Using the opening tool, pry open the keypad platform.
    • You will need to use your hands to get to the laptop’s internal systems by lifting the keypad platform.
  5. Asus G75VW-BHI7N07 USB Port Replacement: 5 단계, 이미지 1/3 Asus G75VW-BHI7N07 USB Port Replacement: 5 단계, 이미지 2/3 Asus G75VW-BHI7N07 USB Port Replacement: 5 단계, 이미지 3/3
    • Now that the fans are exposed, use the opening tool to unhook them at the 4 connecting points.
    • Detach the blue-colored electrical component using the opening tool.
    • Detach the white and black colored electrical component using the opening tool.
  6. Asus G75VW-BHI7N07 USB Port Replacement: 6 단계, 이미지 1/1
    • Using the Phillips #0 Screwdriver, remove the 5 screws around the edges of the motherboard.
    • Remove the 2 screws around the fan using the Phillips #0 Screwdriver which should be near the motherboard.
  7. Asus G75VW-BHI7N07 USB Port Replacement: 7 단계, 이미지 1/1
    • Carefully lift the motherboard up using the opening tool.
    • You should be able to see the USB port.
    • Now you will be able to desolder the faulty USB port.
    • Here is a link on desoldering How To Solder and Desolder Connections
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Joy
회원 가입일: 09/08/17
437 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 10
전체 시간: 599
