주요 콘텐츠로 건너뛰기
Asus K55a-si50301p USB 3.0 Replacement
필요한 것
  1. Asus K55a-si50301p USB 3.0 Replacement, Battery: 1 단계, 이미지 1/1
    • Press and slide the two battery retention clips on either side of the battery towards the unlock position.
  2. Asus K55a-si50301p USB 3.0 Replacement: 2 단계, 이미지 1/1
    • Pull the right side retention clip so that the red indicator is showing.
    • The small graphic below the retention clip denotes locked and unlocked positions. The clip will stay put once moved into position.
  3. Asus K55a-si50301p USB 3.0 Replacement: 3 단계, 이미지 1/1
    • Pull the retention clip on the left hand side of the laptop away from the battery.
    • Gently pull the battery out with your free hand.
  4. Asus K55a-si50301p USB 3.0 Replacement, USB 3.0/Audio Ports: 4 단계, 이미지 1/1
    • Remove the eight Phillips #0 screws.
  5. Asus K55a-si50301p USB 3.0 Replacement: 5 단계, 이미지 1/1
    • Gently pull towards yourself and up to remove the first plastic cover.
  6. Asus K55a-si50301p USB 3.0 Replacement: 6 단계, 이미지 1/2 Asus K55a-si50301p USB 3.0 Replacement: 6 단계, 이미지 2/2
    • Use the iFixit opening tool around the outside line where the top of the laptop meets the bottom to separate components.
  7. Asus K55a-si50301p USB 3.0 Replacement: 7 단계, 이미지 1/1
    • Flip the laptop over and lift the keyboard tray gently towards the screen.
    • Remove the 3 ribbon cables from the motherboard end.
  8. Asus K55a-si50301p USB 3.0 Replacement: 8 단계, 이미지 1/1
    • With the keyboard tray out of the way, remove the tape holding down the accessory board ribbon cable.
  9. Asus K55a-si50301p USB 3.0 Replacement: 9 단계, 이미지 1/1
    • Pull the ribbon cable out of its slot on the USB/Audio port board as shown.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Triston Jones
회원 가입일: 02/12/19
198 평판
안내서 1개 작성함
댓글 한 개
after doing this start button lights up but will not boot
David Garside - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 7
전체 시간: 674
