주요 콘텐츠로 건너뛰기
Asus MeMO Pad HD 8 ME180A SIM Card Reader Replacement
필요한 것
  1. Asus MeMO Pad HD 8 ME180A SIM Card Reader Replacement, Battery: 1 단계, 이미지 1/2 Asus MeMO Pad HD 8 ME180A SIM Card Reader Replacement, Battery: 1 단계, 이미지 2/2
    • Use a plastic opening tool to separate the back half from the front half.
    • Pull the back panel away from the device.
    • The volume buttons can fall out of the case. Be careful not to lose them.
  2. Asus MeMO Pad HD 8 ME180A SIM Card Reader Replacement: 2 단계, 이미지 1/1
    이 단계에 사용된 도구:
    Anti-Static Wrist Strap
    $7.95
    구매
  3. Asus MeMO Pad HD 8 ME180A SIM Card Reader Replacement: 3 단계, 이미지 1/3 Asus MeMO Pad HD 8 ME180A SIM Card Reader Replacement: 3 단계, 이미지 2/3 Asus MeMO Pad HD 8 ME180A SIM Card Reader Replacement: 3 단계, 이미지 3/3
    • Lift the white bar on the ZIF connector and pull the metal connector out.
  4. Asus MeMO Pad HD 8 ME180A SIM Card Reader Replacement: 4 단계, 이미지 1/2 Asus MeMO Pad HD 8 ME180A SIM Card Reader Replacement: 4 단계, 이미지 2/2
    • Using your spudger, press down on the two spots shown in order to release the cables.
    • Ensure that the touchscreen cables are fully disconnected.
  5. Asus MeMO Pad HD 8 ME180A SIM Card Reader Replacement: 5 단계, 이미지 1/2 Asus MeMO Pad HD 8 ME180A SIM Card Reader Replacement: 5 단계, 이미지 2/2
    • Using a PH#0 screwdriver, remove the twelve silver 3.2 mm screws.
    • Pull the battery out.
  6. Asus MeMO Pad HD 8 ME180A SIM Card Reader Replacement, Motherboard: 6 단계, 이미지 1/1
    • Disconnect GPS Antenna cable.
  7. Asus MeMO Pad HD 8 ME180A SIM Card Reader Replacement: 7 단계, 이미지 1/1
    • Flip the latch and pull the ribbon cable to disconnect the ZIF connector.
  8. Asus MeMO Pad HD 8 ME180A SIM Card Reader Replacement: 8 단계, 이미지 1/1
  9. Asus MeMO Pad HD 8 ME180A SIM Card Reader Replacement: 9 단계, 이미지 1/2 Asus MeMO Pad HD 8 ME180A SIM Card Reader Replacement: 9 단계, 이미지 2/2
    • Use a PH#0 screwdriver to unscrew the six 3.0 mm black screws.
    • Lift the motherboard straight up to remove.
  10. Asus MeMO Pad HD 8 ME180A SIM Card Reader Replacement, SIM Card Reader: 10 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Upon removal of the motherboard, desolder the pins that hold the SIM card reader in place.
    • Soldering irons tend to get very hot. Be careful not to burn yourself.
    • Check out iFixit's Soldering Technique Guide to brush up on your soldering skills.
    • Using a pair of tweezers, if desired, pull the sim card straight out.
결론
Rebecca Ellerhorst
회원 가입일: 10/04/16
561 평판
안내서 5개 작성하였습니다
USF Tampa, Team 2-5, Nance Fall 2016 USF Tampa, Team 2-5, Nance Fall 2016 회원
USFT-NANCE-F16S2G5
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 7
전체 시간: 388
