주요 콘텐츠로 건너뛰기
Asus Q503UA-BSI5T17 Fan Removal
필요한 것
  1. Asus Q503UA-BSI5T17 Fan Removal, Battery Replacement: 1 단계, 이미지 1/1
    • Flip the computer upside down. In order to ensure that the correct side is up, you should be able to read the sticker that indicates the serial number on the bottom.
  2. Asus Q503UA-BSI5T17 Fan Removal: 2 단계, 이미지 1/2 Asus Q503UA-BSI5T17 Fan Removal: 2 단계, 이미지 2/2
    • Remove the ten circled screws along the perimeter of the laptop with a Phillips #0 screwdriver.
  3. Asus Q503UA-BSI5T17 Fan Removal: 3 단계, 이미지 1/3 Asus Q503UA-BSI5T17 Fan Removal: 3 단계, 이미지 2/3 Asus Q503UA-BSI5T17 Fan Removal: 3 단계, 이미지 3/3
    • Starting from the top right corner, use a plastic prying tool to separate the cover from the laptop. Use light pressure to prevent the plastic from breaking.
    • You should feel the frame coming loose. If necessary, use spacers to keep the frame from locking back into place.
    • Repeat the above step around the laptop until you are able to lift the cover.
  4. Asus Q503UA-BSI5T17 Fan Removal, Fan: 4 단계, 이미지 1/2 Asus Q503UA-BSI5T17 Fan Removal, Fan: 4 단계, 이미지 2/2
    • Disconnect the two cables connecting the fan to the motherboard.
  5. Asus Q503UA-BSI5T17 Fan Removal: 5 단계, 이미지 1/2 Asus Q503UA-BSI5T17 Fan Removal: 5 단계, 이미지 2/2
    • Remove the two screws from the fan with a Phillips #0 screwdriver.
    • Remove the four screws from the heatsink with a Phillips #0 screwdriver.
  6. Asus Q503UA-BSI5T17 Fan Removal: 6 단계, 이미지 1/1
    • Carefully remove the fan assembly from the laptop.
    • When reinstalling the fan, be sure to clean the contact surfaces on both the CPU and heatsink and reapply fresh thermal paste.
결론
Orlando Garcia
회원 가입일: 08/26/19
359 평판
안내서 2개 작성하였습니다
Gateway, Team S1-G4, Saknee Fall 2019 Gateway, Team S1-G4, Saknee Fall 2019 회원
GCC-SAKNEE-F19S1G4
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 7
전체 시간: 220
