주요 콘텐츠로 건너뛰기
Asus Q505UA-BI5T7 Fan Replacement
필요한 것
  1. Asus Q505UA-BI5T7 Fan Replacement, Back Cover: 1 단계, 이미지 1/2 Asus Q505UA-BI5T7 Fan Replacement, Back Cover: 1 단계, 이미지 2/2
    • Flip the device over so that the back cover is facing you.
    • Ensure that the device is turned off.
    • Remove the two 10 mm Philips #1 screws from the top two corners of the back cover of the laptop.
    • Remove the remaining eight 8 mm Philips #1 screws remaining in the back cover of the laptop.
  2. Asus Q505UA-BI5T7 Fan Replacement: 2 단계, 이미지 1/3 Asus Q505UA-BI5T7 Fan Replacement: 2 단계, 이미지 2/3 Asus Q505UA-BI5T7 Fan Replacement: 2 단계, 이미지 3/3
    • Use the plastic opening tool to gently pry the back cover of the laptop up. Slide the tool slowly along the edges of the back cover to pop it out of the clips holding the cover in place.
  3. Asus Q505UA-BI5T7 Fan Replacement: 3 단계, 이미지 1/1
    • Gently remove the cover and lift it off of the back of the device.
  4. Asus Q505UA-BI5T7 Fan Replacement, Battery: 4 단계, 이미지 1/2 Asus Q505UA-BI5T7 Fan Replacement, Battery: 4 단계, 이미지 2/2
    • Make sure your device is turned off. Remove the 5 mm screws on each respective side of the battery by twisting counter-clockwise with a #0 Phillips screwdriver.
  5. Asus Q505UA-BI5T7 Fan Replacement: 5 단계, 이미지 1/3 Asus Q505UA-BI5T7 Fan Replacement: 5 단계, 이미지 2/3 Asus Q505UA-BI5T7 Fan Replacement: 5 단계, 이미지 3/3
    • Use a plastic opening tool to gently pry off the connected panel.
  6. Asus Q505UA-BI5T7 Fan Replacement: 6 단계, 이미지 1/1
    • Gently lift the battery.
  7. Asus Q505UA-BI5T7 Fan Replacement, Fan: 7 단계, 이미지 1/1
    • Use a Phillips #0 screwdriver to remove the five 5 mm screws on the fan.
  8. Asus Q505UA-BI5T7 Fan Replacement: 8 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Gently remove the white connecter piece with a pair of tweezers.
  9. Asus Q505UA-BI5T7 Fan Replacement: 9 단계, 이미지 1/1
    • Gently lift and remove the fan from the laptop.
결론
Caylin Haffner
회원 가입일: 09/27/23
97 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 22
전체 시간: 66
