주요 콘텐츠로 건너뛰기
Asus Q505UA-BI5T7 Screen Replacement
필요한 것
  1. Asus Q505UA-BI5T7 Screen Replacement, Back Cover: 1 단계, 이미지 1/2 Asus Q505UA-BI5T7 Screen Replacement, Back Cover: 1 단계, 이미지 2/2
    • Flip the device over so that the back cover is facing you.
    • Ensure that the device is turned off.
    • Remove the two 10 mm Philips #1 screws from the top two corners of the back cover of the laptop.
    • Remove the remaining eight 8 mm Philips #1 screws remaining in the back cover of the laptop.
  2. Asus Q505UA-BI5T7 Screen Replacement: 2 단계, 이미지 1/3 Asus Q505UA-BI5T7 Screen Replacement: 2 단계, 이미지 2/3 Asus Q505UA-BI5T7 Screen Replacement: 2 단계, 이미지 3/3
    • Use the plastic opening tool to gently pry the back cover of the laptop up. Slide the tool slowly along the edges of the back cover to pop it out of the clips holding the cover in place.
  3. Asus Q505UA-BI5T7 Screen Replacement: 3 단계, 이미지 1/1
    • Gently remove the cover and lift it off of the back of the device.
  4. Asus Q505UA-BI5T7 Screen Replacement, Battery: 4 단계, 이미지 1/2 Asus Q505UA-BI5T7 Screen Replacement, Battery: 4 단계, 이미지 2/2
    • Make sure your device is turned off. Remove the 5 mm screws on each respective side of the battery by twisting counter-clockwise with a #0 Phillips screwdriver.
  5. Asus Q505UA-BI5T7 Screen Replacement: 5 단계, 이미지 1/3 Asus Q505UA-BI5T7 Screen Replacement: 5 단계, 이미지 2/3 Asus Q505UA-BI5T7 Screen Replacement: 5 단계, 이미지 3/3
    • Use a plastic opening tool to gently pry off the connected panel.
  6. Asus Q505UA-BI5T7 Screen Replacement: 6 단계, 이미지 1/1
    • Gently lift the battery.
  7. Asus Q505UA-BI5T7 Screen Replacement, Screen: 7 단계, 이미지 1/3 Asus Q505UA-BI5T7 Screen Replacement, Screen: 7 단계, 이미지 2/3 Asus Q505UA-BI5T7 Screen Replacement, Screen: 7 단계, 이미지 3/3
    • After following the battery removal guide, use your Ifixit opening tool to pry the two screen connectors off of the laptop motherboard.
    • The screen connector next to the fan must be unwrapped from around the fan so it is free
  8. Asus Q505UA-BI5T7 Screen Replacement: 8 단계, 이미지 1/3 Asus Q505UA-BI5T7 Screen Replacement: 8 단계, 이미지 2/3 Asus Q505UA-BI5T7 Screen Replacement: 8 단계, 이미지 3/3
    • Use a Phillips #0 screwdriver to remove the three 5 mm screws securing each hinge on the laptop.
  9. Asus Q505UA-BI5T7 Screen Replacement: 9 단계, 이미지 1/1
    • Then, gently open the screen a bit and remove the screen from the hinges, being careful with the screen connectors.
  10. Asus Q505UA-BI5T7 Screen Replacement: 10 단계, 이미지 1/3 Asus Q505UA-BI5T7 Screen Replacement: 10 단계, 이미지 2/3 Asus Q505UA-BI5T7 Screen Replacement: 10 단계, 이미지 3/3
    • After removing the screen from the laptop, use a metal pry tool to get within the gap of the screen and the casing.
    • Go all around the screen with the pry tool and detach and lift the screen from the casing.
  11. Asus Q505UA-BI5T7 Screen Replacement: 11 단계, 이미지 1/3 Asus Q505UA-BI5T7 Screen Replacement: 11 단계, 이미지 2/3 Asus Q505UA-BI5T7 Screen Replacement: 11 단계, 이미지 3/3
    • Using your Ifixit opening tool, remove the camera stuck on with an adhesive strip off of the top of the screen.
    • Using the same tool, pry and unclip the bottom touchscreen module from the screen.
    • Before removing the module from the screen, unclip the two ribbon cables still keeping it tethered.
    • Be sure to be careful with the ribbon cables so as to not tear them.
    • You can now remove the touchscreen module connected to the camera from the old screen and transfer it to your new one.
결론
Ivan Melgar
회원 가입일: 09/27/23
121 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 17
전체 시간: 62
