소개
Replacing the battery is helpful when the battery will not hold a charge for an extended period of time. Make sure the computer is unplugged and turned off the entire time. For any other problems follow the device troubleshooting page here.
필요한 것
Remove all ten screws on the back of the laptop to remove the cover.
Remove the cover.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 한 개
Greetings I have tried to pull the battery out but i have issues making it go out of the place where it clicks, could you make a detailed video on how to safely remove that part without breaking the wires or the soldering on the board???
