주요 콘텐츠로 건너뛰기
Asus Q552UB-BHI7T12 MotherBoard Replacement
필요한 것
  1. Asus Q552UB-BHI7T12 MotherBoard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Remove all ten screws on the back of the laptop to remove the cover.
    • Remove the cover.
    I can’t get the cover off after removing all 10 screws.
    Dan A. - 답글
    Ya it seems like there is something attached in the middle but there are no screws in that area.
    Robert Mees - 답글
    Hi. There is a pressure pin in the middle attached to the battery. Just pull gently but firmly up from both sides of the cover and it will snap lose before you bend the cover. A little scary but it works.
    Carlos Villasmil - 답글
  2. Asus Q552UB-BHI7T12 MotherBoard Replacement: 2 단계, 이미지 2개 중 1개 Asus Q552UB-BHI7T12 MotherBoard Replacement: 2 단계, 이미지 2개 중 2개
    • Disconnect the wires at the top of the battery by lifting on the tabs protruding out of the plastic frame.
  3. Asus Q552UB-BHI7T12 MotherBoard Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the four screws holding the battery in place, two on top and one on each side.
  4. Asus Q552UB-BHI7T12 MotherBoard Replacement: 4 단계, 이미지 1개 중 1개
    • Gently lift out the battery by the side closest to the motherboard first.
    • Be careful of any extra wires that may have attached itself to the battery.
  5. Asus Q552UB-BHI7T12 MotherBoard Replacement, MotherBoard: 5 단계, 이미지 1개 중 1개
    • Next you will be removing the cpu fan. Begin by removing the nine screws holding it in place.
  6. Asus Q552UB-BHI7T12 MotherBoard Replacement: 6 단계, 이미지 2개 중 1개 Asus Q552UB-BHI7T12 MotherBoard Replacement: 6 단계, 이미지 2개 중 2개
    • Then unplug the cable connecting into the motherboard.
    • Right next to the wire that was just unplugged, pull up and release the final clip attaching the fan to the motherboard.
    • Finally lift up and place aside.
  7. Asus Q552UB-BHI7T12 MotherBoard Replacement: 7 단계, 이미지 3개 중 1개 Asus Q552UB-BHI7T12 MotherBoard Replacement: 7 단계, 이미지 3개 중 2개 Asus Q552UB-BHI7T12 MotherBoard Replacement: 7 단계, 이미지 3개 중 3개
    • Next remove the screws at the top and bottom of the motherboard.
  8. Asus Q552UB-BHI7T12 MotherBoard Replacement: 8 단계, 이미지 2개 중 1개 Asus Q552UB-BHI7T12 MotherBoard Replacement: 8 단계, 이미지 2개 중 2개
    • Underneath the battery are 3 cables plugging into the motherboard, 1 wide one and two small ones. Lift the white tabs above them up, and then slide them out.
  9. Asus Q552UB-BHI7T12 MotherBoard Replacement: 9 단계, 이미지 1개 중 1개
    • Next you will need to remove the disk drive. You can follow our guide here.
  10. Asus Q552UB-BHI7T12 MotherBoard Replacement: 10 단계, 이미지 1개 중 1개
    • Move to the top of the motherboard and unplug the two cables that are connected.
  11. Asus Q552UB-BHI7T12 MotherBoard Replacement: 11 단계, 이미지 1개 중 1개
    • Move to the bottom of the motherboard and unplug the single cable near the battery.
  12. Asus Q552UB-BHI7T12 MotherBoard Replacement: 12 단계, 이미지 1개 중 1개
    • Now slide the motherboard back toward where the disk drive was, lift up and turn over. You will see a cable connected to the bottom of the board. Pull back on the dark plastic frame and then remove the cable.
    • Set the old motherboard aside and follow the steps in reverse to install the new one.
결론
작성자
1다른 기여자 명과 함께
Alexander Boettcher
회원 가입일: 09/25/17
663 평판
안내서 5개를 작성함
댓글 한 개
Hello. I'll like to know if it's possible to replace the charging port of this laptop. Can I do that, or do I have to replace the whole motherboard
Pulon - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 4
전체 시간: 1,515
