주요 콘텐츠로 건너뛰기
Asus ROG G752V Wireless Card Replacement
필요한 것
  1. Asus ROG G752V Wireless Card Replacement, Keyboard: 1 단계, 이미지 1/2 Asus ROG G752V Wireless Card Replacement, Keyboard: 1 단계, 이미지 2/2
    • Make sure you disconnect the charger before starting this guide.
    • Using a pair of tweezers, remove all 11 rubber plugs off of the back cover.
  2. Asus ROG G752V Wireless Card Replacement: 2 단계, 이미지 1/2 Asus ROG G752V Wireless Card Replacement: 2 단계, 이미지 2/2
    • Using a Phillips #0 screwdriver, remove all twelve 5.2mm screws on the back of the laptop.
    • There is one 5.2 mm screw under the rubber plug in the middle.
  3. Asus ROG G752V Wireless Card Replacement: 3 단계, 이미지 1/1
    • Pull up the rubber seal and the service cover will come off.
  4. Asus ROG G752V Wireless Card Replacement: 4 단계, 이미지 1/1
    • Using the Phillips #00 screwdriver, remove the six 5.2 mm screws under the service cover.
  5. Asus ROG G752V Wireless Card Replacement: 5 단계, 이미지 1/1
    • Using your hands, pull the optical drive out.
  6. Asus ROG G752V Wireless Card Replacement: 6 단계, 이미지 1/2 Asus ROG G752V Wireless Card Replacement: 6 단계, 이미지 2/2
    • Use the iFixit opening tool to pry apart the back panel from the main body of the laptop.
    • Start from the front side of the laptop and then continue to the side for easier access.
  7. Asus ROG G752V Wireless Card Replacement: 7 단계, 이미지 1/2 Asus ROG G752V Wireless Card Replacement: 7 단계, 이미지 2/2
    • Slowly pull out the keyboard while lifting it about an inch.
    • There are cables attached to the keyboard and motherboard. DO NOT lift it more than 2 inches above the laptop.
  8. Asus ROG G752V Wireless Card Replacement: 8 단계, 이미지 1/3 Asus ROG G752V Wireless Card Replacement: 8 단계, 이미지 2/3 Asus ROG G752V Wireless Card Replacement: 8 단계, 이미지 3/3
    • Using an ESD safe tool, detach all 3 ribbon cables. To do so, lift up the cable up and out.
  9. Asus ROG G752V Wireless Card Replacement: 9 단계, 이미지 1/2 Asus ROG G752V Wireless Card Replacement: 9 단계, 이미지 2/2
    • Once the cables are detached, lift the keyboard about 2 inches up and remove it from the rest of the body.
    • Make sure that the screen is open like the photo. This will ensure that none your laptop components will not be bent.
  10. Asus ROG G752V Wireless Card Replacement, Wireless Card: 10 단계, 이미지 1/3 Asus ROG G752V Wireless Card Replacement, Wireless Card: 10 단계, 이미지 2/3 Asus ROG G752V Wireless Card Replacement, Wireless Card: 10 단계, 이미지 3/3
    • Unscrew one 3mm Philips #00 screw on the wireless card.
  11. Asus ROG G752V Wireless Card Replacement: 11 단계, 이미지 1/2 Asus ROG G752V Wireless Card Replacement: 11 단계, 이미지 2/2
    • Using your hands, unlatch the wireless card by pulling it out toward the screen.
    • Gently wiggle the card and pull it out of the motherboard.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Jeong
회원 가입일: 09/16/19
1,149 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 14
30일 전: 61
전체 시간: 2,936
