주요 콘텐츠로 건너뛰기
Asus VivoBook S200E-RHI3T73 DC Jack Replacement
필요한 것
  1. Asus VivoBook S200E-RHI3T73 DC Jack Replacement, DC Jack: 1 단계, 이미지 1/1
    • Before repairing the device, be sure that it is powered off and unplugged.
    • Remove the five 8.0 mm screws using the Phillips #0 screwdriver.
    • Remove the four 5.0 mm screws using the Phillips #0 screwdriver.
    • Carefully remove the back of the laptop and set it aside.
  2. Asus VivoBook S200E-RHI3T73 DC Jack Replacement: 2 단계, 이미지 1/3 Asus VivoBook S200E-RHI3T73 DC Jack Replacement: 2 단계, 이미지 2/3 Asus VivoBook S200E-RHI3T73 DC Jack Replacement: 2 단계, 이미지 3/3
    • Use a Phillips #0 screwdriver to remove the twelve 5.0 mm screws securing the battery.
    • Use a spudger to gently lift the connector tab between the battery and the circuit board.
    • Gently remove the battery from the laptop.
  3. Asus VivoBook S200E-RHI3T73 DC Jack Replacement: 3 단계, 이미지 1/2 Asus VivoBook S200E-RHI3T73 DC Jack Replacement: 3 단계, 이미지 2/2
    • Use a Phillips #0 screwdriver to remove seven screws from the right half of the motherboard.
    • If you are unsure where the motherboard is located please try to refer to the picture as best as you can in order for it to help guide you along the way.
  4. Asus VivoBook S200E-RHI3T73 DC Jack Replacement: 4 단계, 이미지 1/2 Asus VivoBook S200E-RHI3T73 DC Jack Replacement: 4 단계, 이미지 2/2
    • Use a Phillips #0 screwdriver to remove the 5.0 mm screws from the fan and disconnect the fan port.
    • Use the screwdriver to remove remaining screws from the right side of the motherboard.
    • Remove the four screws from the Ethernet port and disconnect the Ethernet port.
    • Pull the motherboard to the left and upward to remove it from the laptop.
  5. Asus VivoBook S200E-RHI3T73 DC Jack Replacement: 5 단계, 이미지 1/1
    • Locate the DC Jack on the motherboard.
    • Use a soldering iron to disconnect the DC Jack from the motherboard.
    • Be careful when soldering, as this can cause injury if done so improperly. It can get very hot and burn.
    • Replace with new DC Jack and solder in to secure it.
결론
This guide gives step by step instructions for replacing the DC Jack on an Asus Vivobook S200E-RHI3T73.
다른 2명이 해당 안내서를 완성하였습니다.
Austin Sypolt
회원 가입일: 04/01/19
139 평판
안내서 1개 작성함
IUPUI, Team S9-G9, Wilson Spring 2019 IUPUI, Team S9-G9, Wilson Spring 2019 회원
IUPUI-WILSON-S19S9G9
4 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 16
전체 시간: 907
