주요 콘텐츠로 건너뛰기
Asus VivoBook X202E-DB21T Power Port Replacement
필요한 것
  1. Asus VivoBook X202E-DB21T Power Port Replacement, Battery: 1 단계, 이미지 1/2 Asus VivoBook X202E-DB21T Power Port Replacement, Battery: 1 단계, 이미지 2/2
    • Flip the device such that the labels are on top.
    • Use a Phillips #1 screwdriver to remove the four 8mm screws near the back.
    • Use the same screwdriver to remove the four 5mm screws in the front.
    • Use the same screwdriver to remove the single 9mm screw in the center.
    • Make sure that the device is powered down and unplugged.
  2. Asus VivoBook X202E-DB21T Power Port Replacement: 2 단계, 이미지 1/2 Asus VivoBook X202E-DB21T Power Port Replacement: 2 단계, 이미지 2/2
    • Remove the back cover by gently prying with a spudger.
  3. Asus VivoBook X202E-DB21T Power Port Replacement: 3 단계, 이미지 1/2 Asus VivoBook X202E-DB21T Power Port Replacement: 3 단계, 이미지 2/2
    • Remove the eight 5mm screws using a Phillips #1 screwdriver.
    • Do not puncture the battery.
  4. Asus VivoBook X202E-DB21T Power Port Replacement: 4 단계, 이미지 1/1
    • Disconnect the battery ribbon cable from the motherboard.
  5. Asus VivoBook X202E-DB21T Power Port Replacement: 5 단계, 이미지 1/1
    • Remove the battery from the laptop.
  6. Asus VivoBook X202E-DB21T Power Port Replacement, Hard Drive: 6 단계, 이미지 1/2 Asus VivoBook X202E-DB21T Power Port Replacement, Hard Drive: 6 단계, 이미지 2/2
    • Unscrew the three 4mm screws holding the hard drive to the board.
  7. Asus VivoBook X202E-DB21T Power Port Replacement: 7 단계, 이미지 1/2 Asus VivoBook X202E-DB21T Power Port Replacement: 7 단계, 이미지 2/2
    • Pull on the tab on the left side of the hard drive and slowly disconnect it from the board.
  8. Asus VivoBook X202E-DB21T Power Port Replacement, Motherboard: 8 단계, 이미지 1/2 Asus VivoBook X202E-DB21T Power Port Replacement, Motherboard: 8 단계, 이미지 2/2
    • Unscrew the five 5mm screws holding the left board together.
  9. Asus VivoBook X202E-DB21T Power Port Replacement: 9 단계, 이미지 1/2 Asus VivoBook X202E-DB21T Power Port Replacement: 9 단계, 이미지 2/2
    • Unplug the two connectors on the left board.
  10. Asus VivoBook X202E-DB21T Power Port Replacement: 10 단계, 이미지 1/3 Asus VivoBook X202E-DB21T Power Port Replacement: 10 단계, 이미지 2/3 Asus VivoBook X202E-DB21T Power Port Replacement: 10 단계, 이미지 3/3
    • Remove the single 3mm screw from the sound chip.
    • Unplug the sound chip.
    • Remove the sound chip.
  11. Asus VivoBook X202E-DB21T Power Port Replacement: 11 단계, 이미지 1/1
    • Remove the six 4mm screws holding the fan and CPU cover.
  12. Asus VivoBook X202E-DB21T Power Port Replacement: 12 단계, 이미지 1/2 Asus VivoBook X202E-DB21T Power Port Replacement: 12 단계, 이미지 2/2
    • Unplug the fan.
    • Remove the fan and CPU cover.
  13. Asus VivoBook X202E-DB21T Power Port Replacement: 13 단계, 이미지 1/1
    • Unscrew the nine 4mm screws holding the right board together.
  14. Asus VivoBook X202E-DB21T Power Port Replacement: 14 단계, 이미지 1/1
    • Remove the two remaining connectors on the board.
  15. Asus VivoBook X202E-DB21T Power Port Replacement: 15 단계, 이미지 1/1
    • Remove the right board.
  16. Asus VivoBook X202E-DB21T Power Port Replacement, Power Port: 16 단계, 이미지 1/1
    • Locate the power port on the right board near the internet port.
  17. Asus VivoBook X202E-DB21T Power Port Replacement: 17 단계, 이미지 1/2 Asus VivoBook X202E-DB21T Power Port Replacement: 17 단계, 이미지 2/2
    • De-solder the pins of the port from the board
    • See this guide on how to use a soldering iron.
    • Remove the port from the board.
결론
다른 2명이 해당 안내서를 완성하였습니다.
John Thomas
회원 가입일: 01/13/19
756 평판
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 20
전체 시간: 956
