소개
In this guide you will learn how to replace your Asus Vivobook X540SA-BPD0602V battery. Batteries should be replaced every couple of years because over time, they will fail to hold a charge. All power sources, including the battery, should be removed before completing any repairs or replacements within the device.
For your safety, discharge your battery below 25% before disassembling your device. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
필요한 것
Power down the laptop using the device's power button in top right corner of the keyboard. Ensure that the device's power cord is disconnected.
Very carefully, remove the batteries with the blue plastic iFixit opening tool. Focus removing the battery near the highlighted area.
다른 3명이 해당 안내서를 완성하였습니다.
