주요 콘텐츠로 건너뛰기
Asus X200CA Display Replacement
필요한 것
  1. Asus X200CA Display Replacement, Display: 1 단계, 이미지 1/1
    • Wedge a metal spudger between the bezel and display cover.
    • Slide the metal spudger back and forth along the top, left, and right sides to pry apart the screen from the outer shell.
  2. Asus X200CA Display Replacement: 2 단계, 이미지 1/2 Asus X200CA Display Replacement: 2 단계, 이미지 2/2
    • Remove the six silver 2.7 mm screws securing the screen bracket to the screen bezel.
  3. Asus X200CA Display Replacement: 3 단계, 이미지 1/2 Asus X200CA Display Replacement: 3 단계, 이미지 2/2
    • Slice the silver foil tape with a spudger by applying pressure between the frame and the back of the screen case.
  4. Asus X200CA Display Replacement: 4 단계, 이미지 1/1
    • Pull apart the black fabric tape with your fingers.
  5. Asus X200CA Display Replacement: 5 단계, 이미지 1/2 Asus X200CA Display Replacement: 5 단계, 이미지 2/2
    • Use an opening tool to peel off the sticker label securing the LCD cable to the LCD display.
    • Gently pull the sticker to disconnect the LCD cable.
    • Potential for device damage: Do not use excessive force while removing the video cable attached to the back of the LCD.
  6. Asus X200CA Display Replacement: 6 단계, 이미지 1/1
    • Lift the LCD screen to remove it from the device.
  7. Asus X200CA Display Replacement: 7 단계, 이미지 1/3 Asus X200CA Display Replacement: 7 단계, 이미지 2/3 Asus X200CA Display Replacement: 7 단계, 이미지 3/3
    • Remove the four silver 2.7 mm screws to separate the LCD screen from the two screen brackets.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Jacqueline Collier
회원 가입일: 10/09/17
1,047 평판
안내서 5개 작성하였습니다
USF Tampa, Team S1-G2, Leahy Fall 2017 USF Tampa, Team S1-G2, Leahy Fall 2017 회원
USFT-LEAHY-F17S1G2
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 13
전체 시간: 1,763
