주요 콘텐츠로 건너뛰기
Asus X553MA-BPD07051 Battery Replacement
필요한 것
동영상 개요
  1. Asus X553MA-BPD07051 Battery Replacement, Battery: 1 단계, 이미지 2개 중 1개 Asus X553MA-BPD07051 Battery Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Use a Phillips #0 screwdriver (PH0 bit) to remove the four 5.0 mm screws that are securing the bottom of the laptop.
    • Use a Phillips #0 screwdriver (PH0 bit) to remove the six 11.0 mm screws that are securing the bottom of the laptop.
  2. Asus X553MA-BPD07051 Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Lift the edges of the keyboard using the plastic iFixit opening tool and raise the keyboard slightly to see the inside of the laptop.
    • Do not lift the keyboard too high as the keyboard is connected to the motherboard by two ribbon connectors that must be detached.
  3. Asus X553MA-BPD07051 Battery Replacement: 3 단계, 이미지 2개 중 1개 Asus X553MA-BPD07051 Battery Replacement: 3 단계, 이미지 2개 중 2개
    • Lift back the clip on the ribbon tape, and pull the tape out in order to remove the keyboard from the laptop.
    • Remove both pieces of the ribbon tape connecting the keyboard to the motherboard.
  4. Asus X553MA-BPD07051 Battery Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the bundled cable connector attaching the battery to the motherboard with the plastic iFixit opening tool.
    • Make sure that you do not remove the entire connector by applying too much force. Only the white plastic connector should be removed from the metal part on the motherboard.
  5. Asus X553MA-BPD07051 Battery Replacement: 5 단계, 이미지 2개 중 1개 Asus X553MA-BPD07051 Battery Replacement: 5 단계, 이미지 2개 중 2개
    • Use Phillips #0 screwdriver (PH0 bit) to remove the four 6.0 mm screws attaching the battery to the laptop.
  6. Asus X553MA-BPD07051 Battery Replacement: 6 단계, 이미지 2개 중 1개 Asus X553MA-BPD07051 Battery Replacement: 6 단계, 이미지 2개 중 2개
    • Lift the battery up and remove it completely from the laptop.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Stephanie DeCarvalho
회원 가입일: 10/21/19
949 평판
안내서 5개를 작성함
UMass Dartmouth, Team S1-G4, Botvin Fall 2019 UMass Dartmouth, Team S1-G4, Botvin Fall 2019 회원
UMASSD-BOTVIN-F19S1G4
3 회원들
안내서 5개를 작성함
댓글 2개
I used your guide when i repaired my mates X553. I found it quite easy. So thanks for the heads up on what to look out for :-)
gazza667 - 답글
Easy with the use of these clear instructions. Thanks and keep up the good work.
Marc Leclair - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 11
지난 30일: 24
전체 시간: 2,581
