주요 콘텐츠로 건너뛰기
Asus ZenBook UX430UA Battery Replacement
필요한 것
  1. Asus ZenBook UX430UA Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Hold the power button to turn off the laptop.
  2. Asus ZenBook UX430UA Battery Replacement: 2 단계, 이미지 1/2 Asus ZenBook UX430UA Battery Replacement: 2 단계, 이미지 2/2
    • Remove the seven T5 Torx screws securing the bottom case to the chassis.
    • Remove the two T5 Torx screws that are threaded differently.
    • The top left and top right screws use different threads than the rest of the screws and should be kept separately to avoid damage.
  3. Asus ZenBook UX430UA Battery Replacement: 3 단계, 이미지 1/1
    • Remove the two rubber feet from the bottom casing.
    • Remove the two screws holding the bottom casing to the chassis using a Phillips #1 screwdriver.
  4. Asus ZenBook UX430UA Battery Replacement: 4 단계, 이미지 1/2 Asus ZenBook UX430UA Battery Replacement: 4 단계, 이미지 2/2
    • Use an iFixit opening tool to gently pry open the bottom case away from the top case.
    • The bottom case is secured to the upper case with four plastic clips near the edges of the laptop.
    • Gently pull the lower case away from the upper case of the laptop by lifting the top first.
  5. Asus ZenBook UX430UA Battery Replacement: 5 단계, 이미지 1/1
    • Use a Phillips 1 screwdriver to remove the five screws holding the battery to the motherboard.
  6. Asus ZenBook UX430UA Battery Replacement: 6 단계, 이미지 1/2 Asus ZenBook UX430UA Battery Replacement: 6 단계, 이미지 2/2
    • Carefully lift the battery from the bottom casing.
    • While removing the battery, ensure that the battery connector is raised enough so that it doesn't get in contact with the motherboard.
    • Lithium-ion batteries can be dangerous if handled poorly. Be cautious to not let any sharp objects near the battery to avoid puncturing it. Use the correct procedures to recycle the battery in your region.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Tanveer Saini
회원 가입일: 09/27/22
133 평판
안내서 1개 작성함
York University, Team B-11, Allen Fall 2022 York University, Team B-11, Allen Fall 2022 회원
YORK-ALLEN-F22SBG11
4 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 39
30일 전: 188
전체 시간: 4,370
