주요 콘텐츠로 건너뛰기
Asus ZenFone 2 Antenna Replacement
필요한 것
  1. Asus ZenFone 2 Antenna Replacement, Removing the Back Cover: 1 단계, 이미지 2개 중 1개 Asus ZenFone 2 Antenna Replacement, Removing the Back Cover: 1 단계, 이미지 2개 중 2개
    • Use your fingernail to gently pry off the phone's back cover at the indicated location. While your fingernail is under the back cover slide your finger around the edges of the phone until the cover pops off.
  2. Asus ZenFone 2 Antenna Replacement, Remove the Inner Cover Screws: 2 단계, 이미지 1개 중 1개
    • Remove the thirteen black screws and the single silver screw from the back of the phone with a JIS size 00 screwdriver.
    • The black screws are 2.8 mm in length.
    • The silver screw is 5.5 mm in length.
    • The black screw next to the camera and the flash is covered by a sticker. This screw can be easily removed as if there were no sticker on top of it. The point of the screwdriver should be able to pierce through the sticker easily.
    The screw next to the camera with the sticker on (top middle on screen) was T4 not J00
    Matthew Hew - 답글
  3. Asus ZenFone 2 Antenna Replacement, Remove the Inner Cover: 3 단계, 이미지 2개 중 1개 Asus ZenFone 2 Antenna Replacement, Remove the Inner Cover: 3 단계, 이미지 2개 중 2개
    • Use a plastic opening tool to remove the inner phone backing.
    • The parts of the inner backing held down by two strips of double sided tape can be easily loosened by inserting the plastic opening tool underneath it and gently lifting it up.
  4. Asus ZenFone 2 Antenna Replacement, Remove the Speaker: 4 단계, 이미지 1개 중 1개
    • Note the position of the speaker unit so you can replace it in the correct place during reassembly.
    • Take the speaker out of the back of the phone. It should come out easily as soon as the inner back is removed because nothing is holding it down in place anymore.
  5. Asus ZenFone 2 Antenna Replacement, Remove the Antenna: 5 단계, 이미지 2개 중 1개 Asus ZenFone 2 Antenna Replacement, Remove the Antenna: 5 단계, 이미지 2개 중 2개
    • Use a plastic opening tool to gently pry up both ends of the antenna.
    • Carefully remove the antenna wire from the plastic keepers along the side. Note their position for reassembly.
    • The antenna connections can be easily bent out of shape. Be sure to lift from underneath the cable as shown.
    It is very important to lift it form underneath... The connector on the motherboard is very fragile.
    Guile - 답글
    Is there any way to actually replace the port? It got ripped off mine.
    Matthew George -
    I am wondering how to repair it, it got ripped off as well.
    matthewdukes -
    Hello Guile,
    I ripped the connector of gsm antenna on the other side (mainboard side) is there any way to fix it? It May be connect another contact point?
    Emrah AKBIYIK -
    same problem...solutions?
    Francesco Marra - 답글
    Same problem any solution?
    cecythebest - 답글
    Same problem too... :(
    Emrah AKBIYIK - 답글
    Is this wifi antenna?
    Dan Ramzi - 답글
결론
Reassemble your device by following the instructions in reverse order.
다른 37명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Eduardo Nodarse
회원 가입일: 02/10/16
4,797 평판
안내서 5개를 작성함
USF Tampa, Team 2-5, Sullivan Spring 2016 USF Tampa, Team 2-5, Sullivan Spring 2016 회원
USFT-SULLIVAN-S16S2G5
4 회원들
안내서 16개를 작성함
댓글 8개
Hi , do you know if this antenna is the only one? I mean is there another antenna for gps signal?
Thanks
Fabio
fcarminato - 답글
What happens when the cable comes off with the little thing underneath?
I was pretty easily happened to me. I don't even know if it is possible to fix.
Said Tahsin Dane - 답글
It was broken and I soldered it.....afterwards sim1 is not working, but sim2 works well, please help me
Rajkumarfilms - 답글
Could you solve it? I had the fact same problem, sadly on the motherboard end, otherwise I'd just replace the USB board, I tried soldering the cable with no luck, sim 1 still won't work.
Sergio Lapunov -
Hi, is this the only antenna for WiFi and bluetooth? Even if I remove it signal is detected.
I have some problems with wifi and bluetooth decreased their power since 2 months, is it the only antenna that I have to replace?
Thanks
Luigi Consoli - 답글
Where can I purchase a new antenna for my Asus ZenFone 2? Z00-AD
Heidi - 답글
Where can I purchase a new antenna connector for the motherboard?
Joao Silva - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 33
전체 시간: 40,193
