주요 콘텐츠로 건너뛰기
Asus ZenFone 3 Zoom Screen Replacement
필요한 것
  1. Asus ZenFone 3 Zoom Screen Replacement, Screen Replacement: 1 단계, 이미지 1/2 Asus ZenFone 3 Zoom Screen Replacement, Screen Replacement: 1 단계, 이미지 2/2
    • Use sim card attachment for the screwdriver found in the IFIXIT box to remove the sim card tray from the phone.
  2. Asus ZenFone 3 Zoom Screen Replacement: 2 단계, 이미지 1/1
    • Remove the 3.5 mm screws on both sides of the charging port, at the bottom of the phone, using the T2 screwdriver.
  3. Asus ZenFone 3 Zoom Screen Replacement: 3 단계, 이미지 1/2 Asus ZenFone 3 Zoom Screen Replacement: 3 단계, 이미지 2/2
    • Use the opening tool to separate the screen and the plastic body of the phone.
  4. Asus ZenFone 3 Zoom Screen Replacement: 4 단계, 이미지 1/1
    • Utilize the PH #00 attachment to remove the two 3.3 mm screws in the bracket to the top left of the battery.
  5. Asus ZenFone 3 Zoom Screen Replacement: 5 단계, 이미지 1/1
    • After removing the bracket and screws, pull up on the battery from the bottom of the unit and set aside.
  6. Asus ZenFone 3 Zoom Screen Replacement: 6 단계, 이미지 1/2 Asus ZenFone 3 Zoom Screen Replacement: 6 단계, 이미지 2/2
    • Remove all three screws near the top of the phone with the PH #00.
    • The top right and left screws are 3.25 mm.
    • The middle screw is 2.65 mm.
  7. Asus ZenFone 3 Zoom Screen Replacement: 7 단계, 이미지 1/1
    • De-solder the single black speaker wire attached on the left side of the phone.
  8. Asus ZenFone 3 Zoom Screen Replacement: 8 단계, 이미지 1/2 Asus ZenFone 3 Zoom Screen Replacement: 8 단계, 이미지 2/2
    • Use the flat-edge side of iFixIt plastic spudger to detach both of the ribbon cables off of the motherboard at their connection point.
  9. Asus ZenFone 3 Zoom Screen Replacement: 9 단계, 이미지 1/2 Asus ZenFone 3 Zoom Screen Replacement: 9 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use the tweezers to lift up on the edges of the motherboard located above where the battery was, then remove the motherboard.
  10. Asus ZenFone 3 Zoom Screen Replacement: 10 단계, 이미지 1/2 Asus ZenFone 3 Zoom Screen Replacement: 10 단계, 이미지 2/2
    • Remove the speaker cover at the bottom of the casing by taking out all five 3.25 mm screws with the PH #00.
  11. Asus ZenFone 3 Zoom Screen Replacement: 11 단계, 이미지 1/1
    • Gently pry off the ribbon cable from speaker housing with the flat-edge side of the iFixit plastic spudger.
  12. Asus ZenFone 3 Zoom Screen Replacement: 12 단계, 이미지 1/1
    • Remove the speaker once exposed.
  13. Asus ZenFone 3 Zoom Screen Replacement: 13 단계, 이미지 1/1
    • Use iOpener to soften the adhesive keeping the screen on the device.
  14. Asus ZenFone 3 Zoom Screen Replacement: 14 단계, 이미지 1/1
    • Pry off the screen beginning at the right-hand side toward the bottom of the phone with the plastic flat-edge spudger.
  15. Asus ZenFone 3 Zoom Screen Replacement: 15 단계, 이미지 1/1
    • Progress around the perimeter of the phone with the pry tool till the screen is off.
  16. Asus ZenFone 3 Zoom Screen Replacement: 16 단계, 이미지 1/2 Asus ZenFone 3 Zoom Screen Replacement: 16 단계, 이미지 2/2
    • Remove the screen by pulling the attached ribbon cable out through the exposed opening.
  17. Asus ZenFone 3 Zoom Screen Replacement: 17 단계, 이미지 1/1
    • The finished product will be a screen with nothing attached to the body of the phone.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Luke Theiss
회원 가입일: 07/10/19
271 평판
안내서 1개 작성함
IUPUI, Team S2-G3, Harley Summer 2019 IUPUI, Team S2-G3, Harley Summer 2019 회원
IUPUI-HARLEY-SU19S2G3
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 17
전체 시간: 2,466
