소개
If your Asus ZenFone 5 has lost its ability to hold a charge, you most likely have a dead battery, which requires replacement.
A functional battery provides power to your cellphone. Eventually, cellphone batteries will rapidly drain after going through a repeated amount of charge cycles. If you notice that your charged battery is draining more quickly than usual, consider calibrating your battery to determine an accurate charging capacity. If you continue to notice significant drops in battery percentage, you should replace your battery.
Make sure to power down your device before you begin. Use ESD safe tools when accessing the battery. ESD safe tools greatly reduce the risk puncturing the battery. A punctured battery can cause a dangerous fire. If your battery is swollen, take appropriate precautions.
필요한 것
Insert a SIM card removal tool or the end of a paperclip into the small hole on the lefthand side of the phone to release the SIM card.
Pull out the SIM card tray.
Use a halberd spudger to pry up the battery's press fit connector from the motherboard.
Gently pry the battery out of the case, taking care not to bend or puncture the battery.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 한 개
Wait, Asus Zenfone 5 (ZE620KL, ZF620KL) has only 3300 mAh battery capacity. Why in the image above the battery label say it's 4000 mAh?
