주요 콘텐츠로 건너뛰기
Asus Zenbook UX303L Keyboard Replacement
필요한 것
  1. Asus Zenbook UX303L Keyboard Replacement, Keyboard: 1 단계, 이미지 1개 중 1개
    • Make sure the device is turned off and disconnected from the battery charger.
  2. Asus Zenbook UX303L Keyboard Replacement: 2 단계, 이미지 3개 중 1개 Asus Zenbook UX303L Keyboard Replacement: 2 단계, 이미지 3개 중 2개 Asus Zenbook UX303L Keyboard Replacement: 2 단계, 이미지 3개 중 3개
    • Remove all the nine screws from the bottom of the device using a T5 screwdriver.
    • Carefully remove the bottom cover.
  3. Asus Zenbook UX303L Keyboard Replacement: 3 단계, 이미지 2개 중 1개 Asus Zenbook UX303L Keyboard Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the LVDS cable next to the cooling fan.
  4. Asus Zenbook UX303L Keyboard Replacement: 4 단계, 이미지 3개 중 1개 Asus Zenbook UX303L Keyboard Replacement: 4 단계, 이미지 3개 중 2개 Asus Zenbook UX303L Keyboard Replacement: 4 단계, 이미지 3개 중 3개
    • Remove the three screws from the hinges using a PH-1 screwdriver.
    • Open the device at a 90 degree angle to free the hinges.
  5. Asus Zenbook UX303L Keyboard Replacement: 5 단계, 이미지 3개 중 1개 Asus Zenbook UX303L Keyboard Replacement: 5 단계, 이미지 3개 중 2개 Asus Zenbook UX303L Keyboard Replacement: 5 단계, 이미지 3개 중 3개
    • Remove the screw attaching the cooling fan to the motherboard by using a PH-1 screwdriver.
    • Disconnect the wire attaching the cooling fan to the motherboard.
    • Gently lift and pull out the cooling fan.
  6. Asus Zenbook UX303L Keyboard Replacement: 6 단계, 이미지 2개 중 1개 Asus Zenbook UX303L Keyboard Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the four screws attached to the black covered copper bar next to the cooling fan using a PH-1 screwdriver.
    • Gently lift and remove the copper bar.
  7. Asus Zenbook UX303L Keyboard Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the five screws from the battery pack using a PH-1 screwdriver.
  8. Asus Zenbook UX303L Keyboard Replacement: 8 단계, 이미지 3개 중 1개 Asus Zenbook UX303L Keyboard Replacement: 8 단계, 이미지 3개 중 2개 Asus Zenbook UX303L Keyboard Replacement: 8 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Unhook the black, red, and white switch using the tweezers.
    • Detach the positive and negative red, white, yellow, and black switch.
    • Unhook the black and white coiled wire.
    • Lift and remove the battery pack.
  9. Asus Zenbook UX303L Keyboard Replacement: 9 단계, 이미지 3개 중 1개 Asus Zenbook UX303L Keyboard Replacement: 9 단계, 이미지 3개 중 2개 Asus Zenbook UX303L Keyboard Replacement: 9 단계, 이미지 3개 중 3개
    • Remove the three screws attaching the drive to the motherboard using a PH-1 screwdriver.
    • Gently lift and pull out the drive.
  10. Asus Zenbook UX303L Keyboard Replacement: 10 단계, 이미지 2개 중 1개 Asus Zenbook UX303L Keyboard Replacement: 10 단계, 이미지 2개 중 2개
    • Remove the silver tape to free the fourth screw attaching the motherboard.
    • Remove the four screws attaching the motherboard using a PH-1 screwdriver.
  11. Asus Zenbook UX303L Keyboard Replacement: 11 단계, 이미지 2개 중 1개 Asus Zenbook UX303L Keyboard Replacement: 11 단계, 이미지 2개 중 2개
    • Detach the four wires connected to the motherboard using tweezers.
    • Gently lift up and pull out the motherboard.
  12. Asus Zenbook UX303L Keyboard Replacement: 12 단계, 이미지 3개 중 1개 Asus Zenbook UX303L Keyboard Replacement: 12 단계, 이미지 3개 중 2개 Asus Zenbook UX303L Keyboard Replacement: 12 단계, 이미지 3개 중 3개
    • Remove the small piece of the motherboard on the lower left hand corner by removing the four screws using a PH-1 screwdriver.
    • Detach the black and red coiled wire from the motherboard using tweezers.
    • Gently lift and remove the small piece of the motherboard.
  13. Asus Zenbook UX303L Keyboard Replacement: 13 단계, 이미지 2개 중 1개 Asus Zenbook UX303L Keyboard Replacement: 13 단계, 이미지 2개 중 2개
    • Place the plastic opening tool under the corners of the keyboard and use it to detach the keyboard all around.
    • Gently lift and remove the keyboard from its place.
결론
다른 7명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Bianka Castaneda
회원 가입일: 10/13/15
469 평판
안내서 2개를 작성함
Sam Houston State, Team 1-3, Blackburne Fall 2015 Sam Houston State, Team 1-3, Blackburne Fall 2015 회원
SHSU-BLACKBURNE-F15S1G3
3 회원들
안내서 4개를 작성함
댓글 8개
Please tell me where did you buy the keyboard replace, I am looking for it in order to do the replacement for an UX303L (with spanish or english layout with big enter key). Thanks.
Pm - 답글
Step 2: There are screws under the rubber pads (at least on the UX303L).
Peter Sutton - 답글
Step 9: Its removing the hard drive/SSD not RAM.
Peter Sutton - 답글
Step 13: Please show me how to remove the keyboard out. It will break some plastic to pull the keyboard out.
Thanks,
Quang
Quang Nguyen - 답글
Battery pack should be removed first (at least before step 3) in order to avoid possible power surge
Andrey Arkhipov - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 15
지난 30일: 52
전체 시간: 21,218
